Cert for SIP RFC 5922
thanos.babblevoice.com
certbot certonly --manual --preferred-challenges=dns -d thanos.babblevoice.com -d sip:thanos.babblevoice.com -d sip:bling.babblevoice.com --duplicate
An unexpected error occurred:
The server will not issue certificates for the identifier :: Error creating new order :: Cannot issue for “sip”: Domain name needs at least one dot
CentOS 7
Freeswitch
Yes
No
certbot 1.3.0
I am trying to configure FS for use with TLS but I am struggling. SSL/TLS I have a working knowledge - ut not in-depth. I have generated a cert which appears to work - browsers like A WebSocket server running with it.
RFC 5922 has the matching protocol for SIP clients to perform to verify any certificate presented. 7.1. Finding SIP Identities in a Certificate.
URI If the scheme of the URI is not “sip”, then the implementation MUST NOT accept the value as a SIP domain identity.
When I try to add sip: URI to the certbot command it returns that error.
I think the way URI scheme SIP is similiar to URI HTTPS or HTTP, and according to a tutorial i searched online (I don't have experience with configuring SIP), there should have no problem using a Let's Encrypt certificate with SIP.
So the command should simply be: certbot certonly --manual --preferred-challenges=dns -d thanos.babblevoice.com -d bling.babblevoice.com --duplicate
Tutorial i found: How to Create Certificates for the SIP Proxy | Barracuda Campus
P.S. I might be wrong, but if SIP certificate requires a new URI in SAN, there should be a bunch of commercial CAs selling SIP certificate.
The CA/B Forum Baseline Requirements only allow dNSName and iPAddress as SubjectAltName types, not an URI.
Also: rfc822Name for email😂
Thanks all. Your comments definitly helped.
The RFC is misleading on this point. After much frigging about with phone and server settings the normal -d method works fine.
