Cert fail when test using https://www.checktls.com/
mail.thetranslationgate.com
Check How You Get Email (Receiver Test) FREE
cert fail
apache2
Ubuntu 16.04
aws
Webmin
certbot 0.31.0
So you've got A LOT OF certificates already issued for mail.thetranslationgate.com.
However, Postfix is still using a self-signed certificate. Interestingly enough, your Dovecot is sporting one of the valid certificates.
How does Webmin control the TLS certificates used by Postfix?
Also, I would like to urge you not to issue so many certificates. There are a LOT of duplicates. This is adding unnecessary load and strain on the Let's Encrypt infrastructure. Also, you could run into rate limits.
Thank you for your reply,
First how I know the valid one and remove the rest?
I want to keep letsencrypt infrastructure safe and performs well :slight_smile:
Webmin deal like the setting say below:
Hostnames for certificate:mail.thetranslationgate.com
Website root directory for validation file:/var/www/html
Copy new key and certificate to Webmin?:yes
SSL key size:default
Let's Encrypt server:Real
Months between automatic renewal: Only renew manually
Well, crt.sh just shows all certificates issued in the past, recent or older. It's not a representation of the certificates actually on your server. And I have no clue how the Webmin certificate management works.
That's not very much.. It doesn't specify Postfix or SMTP anywhere?
According to this thread, there should be a "Copy to Postfix" button somewhere: I need to get TLS set up on Postfix on my CentOS 5.7 server running Virtualmin 3.95 | Virtualmin
I see the below details in /etc/postfix/main.cf
TLS parameters
The default snakeoil certificate. Comment if using a purchased
SSL certificate.
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
and
Uncomment if using a purchased SSL certificate.
smtpd_tls_cert_file=/etc/ssl/certs/example.com.crt
smtpd_tls_key_file=/etc/ssl/private/example.com.key
So postfix is using snakeoil certificate now
I see that we need to know the paths for the certs too. So I found in:
/etc/dovecot/conf.d/10-ssl.conf
Let's Encrypt certificate:
ssl_cert = </etc/letsencrypt/live/mail.thetranslationgate.com/fullchain.pem
ssl_key = </etc/letsencrypt/live/mail.thetranslationgate.com/privkey.pem
My question if I change like below, The cert issue will be solved?
smtpd_tls_cert_file=/etc/letsencrypt/live/mail.thetranslationgate.com/fullchain.pem
smtpd_tls_key_file=/etc/letsencrypt/live/mail.thetranslationgate.com/privkey.pem
Most likely: yes.
Don't forget you'll need to reload Postfix and Dovecot when the certificate has been renewed. I recon that's not something Webmin will do for you when it renews your certificate.
