Cerbot for IoT device
I'm trying to generate a cert for an IoT device on a local network. This just uses the hostname so it's not a traditional URL. I'm also interested in trying the IP address cert but I don't think that's released yet.
certbot certonly --standalone --register-unsafely-without-email -d <my device name>
An unexpected error occurred:
The server will not issue certificates for the identifier :: Invalid identifiers requested :: Cannot issue for "<my device name>": Domain name needs at least one dot
Mongoose 7.18
Ubuntu 20.04
Yes
The version of my client is: certbot 0.40.0
Public certificate needs a public name
(even if it's unreachable and you use the dns-01 challenge to validate)
You're right, but you'll need a much newer version of certbot for that.
Indeed, one that hasn't been released yet.
If you want a certificate from Let’s Encrypt, you will need to register a domain. Since the device has a private IP address, I would recommend using the dns-01 challenge.
In the future, you will be able to get certs for IP addresses, but keep in mind that those are only for non-private IP addresses. So 192.168.0.0/16, 10.0.0.0/8, etc, are out of the question.
Another option is to use a certificate that is chained to a private root certificate that you control. There are multiple ways to do that, I would recommend having a look at Filippo Valsorda’s tool mkcert.
