LetsEncrypt Certbot Not detecting IP
antoniswebsite.hopto.org
certbot certonly --standalone
Please enter in your domain name(s) (comma and/or space separated) (Enter 'c'
to cancel): antoniswebsite.hopto.org
Requesting a certificate for antoniswebsite.hopto.org
http-01 challenge for antoniswebsite.hopto.org
Challenge failed for domain antoniswebsite.hopto.org
Domain: antoniswebsite.hopto.org
Type: dns
Detail: No valid IP addresses found for antoniswebsite.hopto.org
Apache 2.4.46
Windows 10 Home 20H2
N/A
I don't know
No
Certbot 1.12.0
I have a valid A record toward' s my web server. I have tried both public and private ip addresses. I have also tried some other authentication plugins but they do not work as well. My domain provider is No-Ip so I cannot add TXT records.
Any help would be appreciated.
Hi @swanserquack
that's
D:\temp>nslookup antoniswebsite.hopto.org.
Address: 192.168.56.1
not a public visible ip address, that's only a private ip address.
A public ip address is required if you want to use http validation.
I have changed it to my public ip and I get:
Type: connection
Detail: Fetching
http://antoniswebsite.hopto.org/.well-known/acme-challenge/vZ028twCg8rEPF1gvfiN-xMytJKfTpyzChq5lPs0Z88:
And what's now your question?
There
is your error, fix that.
Thanks for your help. Forgot to setup port forwarding.
Yep, that's required. Happy to read you found the solution :+1:
