Hello,
I want to run a VPN-Server behind a firewall using the openvpn Port 1194, and i try to get a certificate for that.
Thats the only port pointing to that machine from the Internet (at the moment).
I can connect through SSH from the Internet, but that access is locked to a few specific IP-Addresses.
I tried to read through similar topics but couldn’t really find a solution to my problem (my engish might not be good enough to filter relevant answers from other topics).
What I did / tried so far:
First I stopped the VPN-Server to free up the port (1194).
Then I tried to get a certificate from LE.
- command:
certbot certonly --tls-sni-01-port 1194
(‘1: Spin up a temporary webserver (standalone)’) - Output:
tls-sni-01 challenge for enzian.vpn.eiskalt.at
Waiting for verification…
Failed authorization procedure. enzian.vpn.eiskalt.at (tls-sni-01): urn:acme:err or:connection :: The server could not connect to the client to verify the domain :: Timeout
Domain: enzian.vpn.eiskalt.at
Type: connection
Detail: Timeout
Following tries with a webserver started (nginx) listening on 1194
(the webserver was accessable and responded with the standard page)
- command:
certbot certonly --webroot -w /usr/share/nginx/html/ -d enzian.vpn.eiskalt.at --tls-sni-01-port 1194 - output:
http-01 challenge for enzian.vpn.eiskalt.at
Using the webroot path /usr/share/nginx/html for all unmatched domains.
Failed authorization procedure. enzian.vpn.eiskalt.at (http-01): urn:acme:error: connection :: The server could not connect to the client to verify the domain :: Fetching http://enzian.vpn.eiskalt.at/.well-known/acme-challenge/8aylDqLw6qQPCL Jm0gz-8JxYrBYzdXiSPtKYFGanbNA: Timeout
Type: connection
Detail: Fetching
http://enzian.vpn.eiskalt.at/.well-known/acme-challenge/8aylDqLw6qQPCLJm0gz-8 JxYrBYzdXiSPtKYFGanbNA:
Timeout
- tried with http-01 instead of tls-sni-01
- command:
certbot certonly --webroot -w /usr/share/nginx/html/ -d enzian.vpn.eiskalt.at --http-01-port 1194 - Output:
Failed authorization procedure. enzian.vpn.eiskalt.at (http-01): urn:acme:error: connection :: The server could not connect to the client to verify the domain :: Fetching http://enzian.vpn.eiskalt.at/.well-known/acme-challenge/Xpkh3Zm9kKHQMs PwfKpZ2NCMrclYUxfmxzFzk4095NA: Timeout
Type: connection
Detail: Fetching
http://enzian.vpn.eiskalt.at/.well-known/acme-challenge/Xpkh3Zm9kKHQMsPwfKpZ2 NCMrclYUxfmxzFzk4095NA:
Timeout
It seems to me, as if this procedure (getting a certificate with certbot) needs two ports (80 and 443).
If this is the case, would it be possible to use port 1194 for http (with --http-01-port 1194) and port 44300 for https (with --tls-nsi-01-port 44300) as the ports 80 and 443 are not available (i don’t get them forwarded to my machine).
I am not in charge of the firewall, so i don’t want to try different options, cause i always have to ask others to change settings.
If ports below 1024 needed, I may be able to request forwarding from 81 and 444 (or something similar). The Administrator of the firewall is in general not too happy to open ports below 1024 to be accessable from everywhere from the internet. If ports below 1024 needed is there a possibility to limit access to an IP or IPrange?
Or do i have an error in the commands i tried to optain a certificate?
Kind regards
Oliver
more than one … listed above
nginx/1.10.2
Centos Linux 7
yes, but locked to specific IP-addresses
