# cat /proc/version
Linux version 2.6.32-696.1.1.el6.x86_64 (mockbuild@c1bm.rdu2.centos.org) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-18) (GCC) ) #1 SMP Tue Apr 11 17:13:24 UTC 2017
# lsb_release -a
LSB Version: :base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch
Distributor ID: CentOS
Description: CentOS release 6.9 (Final)
Release: 6.9
Codename: Final
# free -m
total used free shared buffers cached
Mem: 2006 1107 898 14 30 390
-/+ buffers/cache: 686 1319
Swap: 1023 0 1023
# which nginx
/usr/bin/which: no nginx in (/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin:/usr/mpich/bin::/usr/local/go/bin)
# which httpd
/usr/sbin/httpd
# ./certbot-auto -v
Bootstrapping dependencies for RedHat-based OSes… (you can skip this with --no-bootstrap)
yum is /usr/bin/yum
Loaded plugins: fastestmirror, priorities, refresh-packagekit
Setting up Install Process
Repository base is listed more than once in the configuration
Repository updates is listed more than once in the configuration
Repository extras is listed more than once in the configuration
Repository epel is listed more than once in the configuration
Loading mirror speeds from cached hostfile
- base: mirrors.cloud.aliyuncs.com
- epel: mirrors.cloud.aliyuncs.com
- extras: mirrors.cloud.aliyuncs.com
- updates: mirrors.cloud.aliyuncs.com
- webtatic: us-east.repo.webtatic.com
Package gcc-4.4.7-18.el6.x86_64 already installed and latest version
Package augeas-libs-1.0.0-10.el6.x86_64 already installed and latest version
Package openssl-1.0.1e-57.el6.x86_64 already installed and latest version
Package openssl-devel-1.0.1e-57.el6.x86_64 already installed and latest version
Package libffi-devel-3.0.5-3.2.el6.x86_64 already installed and latest version
Package redhat-rpm-config-9.0.3-51.el6.centos.noarch already installed and latest version
Package ca-certificates-2017.2.14-65.0.1.el6_9.noarch already installed and latest version
Package python-2.6.6-66.el6_8.x86_64 already installed and latest version
Package python-devel-2.6.6-66.el6_8.x86_64 already installed and latest version
Package python-virtualenv-1.10.1-1.el6.noarch already installed and latest version
Package python-tools-2.6.6-66.el6_8.x86_64 already installed and latest version
Package python-pip-7.1.0-1.el6.noarch already installed and latest version
Package 1:mod_ssl-2.2.15-60.el6.centos.5.x86_64 already installed and latest version
Nothing to do
Creating virtual environment…
Already using interpreter /usr/local/bin/python2.7
New python executable in /opt/eff.org/certbot/venv/bin/python2.7
Also creating executable in /opt/eff.org/certbot/venv/bin/python
Please make sure you remove any previous custom paths from your /root/.pydistutils.cfg file.
Installing setuptools, pip, wheel…done.
Installing Python packages…
Collecting argparse==1.4.0 (from -r /tmp/tmp.8BgtBfovHO/letsencrypt-auto-requirements.txt (line 11))
Downloading
// deleted, new user can only have 20 links at most in this post
Collecting certbot-nginx==0.18.1 (from -r /tmp/tmp.8BgtBfovHO/letsencrypt-auto-requirements.txt (line 211))
Could not find a version that satisfies the requirement certbot-nginx==0.18.1 (from -r /tmp/tmp.8BgtBfovHO/letsencrypt-auto-requirements.txt (line 211)) (from versions: 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.9.1, 0.9.2, 0.9.3, 0.10.0, 0.10.1, 0.10.2, 0.11.0, 0.11.1, 0.12.0, 0.13.0, 0.14.0, 0.14.1, 0.14.2, 0.15.0, 0.16.0, 0.17.0, 0.18.0)
No matching distribution found for certbot-nginx==0.18.1 (from -r /tmp/tmp.8BgtBfovHO/letsencrypt-auto-requirements.txt (line 211))
Had a problem while installing Python packages.
