Hi everyone
My domain is: uniatitude.com.br
I ran this command: certbot-auto [with any option]
Bootstrapping dependencies for RedHat-based OSes… (you can skip this with --no-bootstrap)
yum is /usr/bin/yum
To use Certbot, packages from the EPEL repository need to be installed.
Enable the EPEL repository and try running Certbot again.
Server version: Apache/2.2.15 (Unix)
Server built: Jun 19 2018 15:45:13
CentOS 6.
I can login to a root shell on my machine: (yes or no, or I don’t know): YES
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): NO
No correct answer… just this answer
certbot-auto --version
yum is /usr/bin/yum
It was working very well but, i dont know why, became a problem to me!
I reinstalled certbot and still have the same problem.
The reported message does not tell me which EPEL to enable.
I installed EPEL repo, and certbot -v report
Creating virtual environment…
File “”, line 27, in
File “”, line 19, in create_venv
File “/opt/rh/python27/root/usr/lib64/python2.7/subprocess.py”, line 185, in check_call
retcode = call(*popenargs, **kwargs)
File “/opt/rh/python27/root/usr/lib64/python2.7/subprocess.py”, line 172, in call
return Popen(*popenargs, **kwargs).wait()
File “/opt/rh/python27/root/usr/lib64/python2.7/subprocess.py”, line 394, in init
errread, errwrite)
File “/opt/rh/python27/root/usr/lib64/python2.7/subprocess.py”, line 1047, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
my certificate directory still ok on /etc/letsencrypt but My certificates will expire in a few days.
Please, help me.
