alanvilla.com
I ran this cronjob:
41 21 * * * /usr/bin/certbot renew >> /var/log/le-renew.log
43 21 * * * /usr/bin/systemctl reload nginx
It produced this output in mail:
Could not choose appropriate plugin: The nginx plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError()
Attempting to renew cert (alanvilla.com) from /etc/letsencrypt/renewal/alanvilla.com.conf produced an unexpected error: The nginx plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError(). Skipping.
/etc/letsencrypt/live/alanvilla.com/fullchain.pem (failure)
nginx/1.12.2
Operating System: CentOS Linux 7 (Core)
CPE OS Name: cpe:/o:centos:centos:7
Kernel: Linux 3.10.0-693.17.1.el7.x86_64
Architecture: x86-64
digital ocean
no
Notes:
When I ran certbot renew manually it worked and renewed the certificate with no issues. But the cron job kept failing.
