This automated renewal failed:
Processing /usr/local/etc/letsencrypt/renewal/paulbeard.org.conf
Non-interactive renewal: random delay of 42.27417180936647 seconds
Could not choose appropriate plugin: The nginx plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError("Could not find a usable 'nginx' binary. Ensure nginx exists, the binary is executable, and your PATH is set correctly.")
Attempting to renew cert ([paulbeard.org](http://paulbeard.org/)) from /usr/local/etc/letsencrypt/renewal/paulbeard.org.conf produced an unexpected error: The nginx plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError("Could not find a usable 'nginx' binary. Ensure nginx exists, the binary is executable, and your PATH is set correctly."). Skipping.
Running the same command manually worked.
http-01 challenge for paulbeard.org
new certificate deployed with reload of nginx server; fullchain is
/usr/local/etc/letsencrypt/live/paulbeard.org/fullchain.pem
paulbeard.org
see above
see above
nginx 1.7
FreeBSD
None
no
certbot 1.4.0
