Can't renew During secondary validation: Fetching xxx Connection reset by peer
My domain is: beterwork-us.hopto.org
sudo certbot --apache
hans@beterwork-us:/etc$ sudo certbot --apache
[sudo] password for hans:
1: beterwork-us.hopto.org
blank to select all options shown (Enter ‘c’ to cancel): 1
http-01 challenge for beterwork-us.hopto.org
Enabled Apache rewrite module
Waiting for verification…
Failed authorization procedure. beterwork-us.hopto.org (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: During secondary validation: Fetching http://beterwork-us.hopto.org/.well-known/acme-challenge/l0gS7bOnsorr23Me8_BxI3a1RG6lij5u_LDa8umpdyg: Connection reset by peer
    Domain: beterwork-us.hopto.org
    Type: connection
    Detail: During secondary validation: Fetching
ii apache2 2.4.29-1ubuntu4.12 amd64 Apache HTTP Server
Ubuntu 18.04.2 LTS
https://manage.hostdare.com/
no
certbot 0.31.0
---- Comments ----
half years ago I run certbot have no issue
today I got a email tell me to renew I found I can’t keep give me
error.
I even ran the manual mode
sudo certbot certonly --manual --preferred-challenges http
put a file into the www root make visiable to public
http://beterwork-us.hopto.org/.well-known/acme-challenge/Pts5d2vqPLOP9A-YGaYFA9RU7hWUWGZ4vmSaStnv_6c
but still give me this error.
is there anything I can do?
By the way I already clear all iptables
and accectped all
with command
sudo iptables -I INPUT -j ACCEPT
Have you confirmed your IP address?
I see:
Address:  193.22.152.202
Is there any special handling for the /.well-known/acme-challenge/ requests?
I can reach:
It shows:
Pts5d2vqPLOP9A-YGaYFA9RU7hWUWGZ4vmSaStnv_6c.LOTiAPJFBQGCUGPqZn2_Tr-6q4HOca0Au_csvdUxwTk
[which looks correct]
Do you have any firewall rules or devices in front of your server that may be affecting traffic from AWS?
Recently Let’s Encrypt began checking challenges from 4 different hosts simultaneously: ACME v1/v2: Validating challenges from multiple network vantage points
Your error indicates that one of the secondary perspectives (which are currently hosted with AWS) failed to fetch the challenge file from your server.
Does this error happen consistently or just sometimes?
It happens consistently
I already disabled firewall totally.
Hi @beterhans
your error message
says: The Letsencrypt data center can fetch your file. The servers used with multi perspective validation can't.
So you have a regional firewall that blocks -> remove that.
Hi Thanks JuergenAuer for the reply
How could I know the IP Range for the Secondary server’s IP?
I will ask my VM provider if they have a firewall against that range.
Please read the FAQ:
Letsencrypt doesn't publish ip addresses. And secondary validation -> ip addresses may change.
Hi JuegenAuer Thanks for the reply
But it turns out it’s not my side blocked AWS server’s request it’s AWS server reseted tcp connection for some reason.
Here is a wireshark I did on my VM’s eth0
This is the 1st OK one
IP end with 202 is my Server, other side is the LetEncrypt server
Following is the Failed one.
AWS server sent a reset for some reason.
