My domain is:app.fuelmatix.co
I ran this command:sudo certbot renew --verbose
/usr/lib/python3.6/site-packages/OpenSSL/_util.py:6: CryptographyDeprecationWarning: Python 3.6 is no longer supported by the Python core team. Therefore, support for it is deprecated in cryptography. The next release of cryptography will remove support for Python 3.6.
from cryptography.hazmat.bindings.openssl.binding import Binding
Python 3.6 support will be dropped in the next release of Certbot - please upgrade your Python version.
Processing /etc/letsencrypt/renewal/app.fuelmatix.co.conf
Certificate is due for renewal, auto-renewing...
Failed to renew certificate app.fuelmatix.co with error: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Read timed out. (read timeout=45)
/etc/letsencrypt/live/app.fuelmatix.co/fullchain.pem (failure)
My web server is (include version):Server version: Apache/2.4.6 (CentOS)
Server built: Apr 2 2020 13:13:23
The operating system my web server runs on is (include version):Sangoma Linux release 7.8.2003 (Core
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 1.23.0
