Can't renew cert with Docker and Certbot
Using guide from this site.
My domain is: ihmg-ua.com
docker run -t --rm \
      -v remote_certs:/etc/letsencrypt \
      -v remote_certs-data:/data/letsencrypt \
      deliverous/certbot \
      --webroot --webroot-path=/data/letsencrypt
Attempting to renew cert (ihmg-ua.com) from /etc/letsencrypt/renewal/ihmg-ua.com.conf produced an unexpected error: Failed authorization procedure. ihmg-ua.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://ihmg-ua.com/.well-known/acme-challenge/HhFgqEre2ghBxy5phI_qncIjxx4JL9HI3f_3y0JXNjw [68.183.234.249]: "<html>\r\n<head><title>404 Not Found</title></head>\r\n<body bgcolor=\"white\">\r\n<center><h1>404 Not Found</h1></center>\r\n<hr><center>". Skipping.
  /etc/letsencrypt/live/ihmg-ua.com/fullchain.pem (failure)
nginx/1.14.2
Debian 9
0.31.0.dev0
My nginx .conf:
  map $http_upgrade $connection_upgrade {
  default upgrade;
  ''      close;
    listen 80;
    server_name ihmg-ua.com;
    listen 443 ssl;
    gzip                      on;
    client_max_body_size      4M;
    ssl                       off;
    add_header                Strict-Transport-Security "max-age=31536000" always;
    ssl_session_cache         shared:SSL:20m;
    ssl_session_timeout       10m;
    ssl_protocols             TLSv1 TLSv1.1 TLSv1.2;
    ssl_prefer_server_ciphers on;
    ssl_ciphers               "ECDH+AESGCM:ECDH+AES256:ECDH+AES128:!ADH:!AECDH:!MD5;";
    ssl_stapling              on;
    ssl_stapling_verify       on;
    resolver                  8.8.8.8 8.8.4.4;
    ssl_certificate           /etc/letsencrypt/live/ihmg-ua.com/fullchain.pem;
    ssl_certificate_key       /etc/letsencrypt/live/ihmg-ua.com/privkey.pem;
    ssl_trusted_certificate   /etc/letsencrypt/live/ihmg-ua.com/chain.pem;
    access_log                /dev/stdout;
    error_log                 /dev/stderr info;
        proxy_pass http://pscc/;
        proxy_http_version 1.1;
        proxy_set_header   Upgrade $http_upgrade;
        proxy_set_header   Connection $connection_upgrade;
    location ^~ /.well-known {
        allow all;
        root  /data/letsencrypt/;
        root /var/www/certbot;
Welcome to the Let's Encrypt Community, Enver :slightly_smiling_face:
Is that really the root of your website content?
See @sahsanu's post below for more details.
Hello @Tash,
In your docker command you are using /data/letsencrypt as webroot but in your nginx conf you are using /var/www/certbot
You should fix that.
Cheers,
sahsanu
sahsanu,
I'm eternally grateful for your help!
@sahsanu to the rescue!
"You have saved our lives. We are eternally grateful."
Aliens | Pixar | Toy Story 2
