Can't reach site with https, took too long to respond
I am completely new to all things web, and am trying to create an ssl certificate for use in experimenting with various applications that require https. I have set up dynamic dns to point to an apache2 server running on my home computer (referenced in the following).
After setting up an ssl key I still cannot reach the site via https (http works completely fine still), it says it times out. Info below:
shaunserver.ddns.net
./certbot-auto -d shaunserver.ddns.net
Congratulations! You have successfully enabled https://shaunserver.ddns.net
https://www.ssllabs.com/ssltest/analyze.html?d=shaunserver.ddns.net
    /etc/letsencrypt/live/shaunserver.ddns.net/fullchain.pem
    /etc/letsencrypt/live/shaunserver.ddns.net/privkey.pem
    Your cert will expire on 2018-11-14. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot-auto
    again with the “certonly” option. To non-interactively renew all
    of your certificates, run “certbot-auto renew”
however, when I attempt to do as suggested and test my configuration via the provided site, or simply typing into the url “https://shaunserver.ddns.net” it times out, typing the same without the ‘s’ in ‘https’, however, works fine.
Server version: Apache/2.4.18 (Ubuntu)
Ubuntu 16.04.4 LTS
no
Here are dumps (minus the comments) of my 000-default.conf and default-ssl.conf files
000-default.conf
<VirtualHost *:80>
	DocumentRoot /var/www/html
        ServerName shaunserver.ddns.net
        ServerAlias shaunserver.ddns.net
</VirtualHost>
defualt-ssl.conf
<IfModule mod_ssl.c>
	<VirtualHost _default_:443>
		SSLEngine on
		SSLCertificateFile /etc/letsencrypt/live/shaunserver.ddns.net/fullchain.pem
		SSLCertificateKeyFile /etc/letsencrypt/live/shaunserver.ddns.net/privkey.pem
		<FilesMatch "\.(cgi|shtml|phtml|php)$">
				SSLOptions +StdEnvVars
		</FilesMatch>
		<Directory /usr/lib/cgi-bin>
		</Directory>
	</VirtualHost>
</IfModule>
Thank you so much for your help!
Hi @Salsum
is there a firewall that blocks port 443?
There was indeed, I forwarded the port and it now works, thank you so much!
I guess I didn’t realize that http and https used different ports, though I suppose that is obvious now that I look at my “ports.conf” file in apache2.
How does the “Listen” command in my “ports.conf” file work? When it says
Listen 80
<IfModule ssl_module>
        Listen 443
</IfModule>
does it listen on both 80 and 443?
Could I, for instance, also listen on another port and stop forwarding these so that I don’t mess with other traffic on my router (there is currently none, but thinking towards the future if there ends up being a separate server, for instance)?
For instance, adding
Listen 4443
then having shaunserver.ddns.net:4443 access the server instead.
Anyway, thanks again!
Yes, then port 80 and port 443 are used.
Yes, that should work. But then https://shaunserver.ddns.net:4443 - using non-standard-ports, you have to use both - protocol and port.
But it should also work that extern is 443 used ( https://shaunserver.ddns.net/ ) and your router sends the traffic to port 4443 of your internal server.
There are a lot of users with such different configurations.
