Can't get certbot to work successfully
I can’t see why this is failing…
Let’s try --webroot method.
Since we still have that Alias for /.well-known/acme-challenge/, we really don’t need to be accurate about the actual webroot used.
Try this test:
certbot certonly --webroot -w /var/www/html -d voidcitymc.com --staging
Exactly the same error as before
Is there anything meaningful in the error.log file?
/var/log/apache2/error.log
[Wed Nov 06 01:33:09.168638 2019] [mpm_prefork:not$[Wed Nov 06 01:33:09.168769 2019] [core:notice] [p$[Wed Nov 06 01:39:15.943672 2019] [mpm_prefork:not$AH00558: apache2: Could not reliably determine the$[Wed Nov 06 01:39:16.301235 2019] [mpm_prefork:not$[Wed Nov 06 01:39:16.301351 2019] [core:notice] [p$[Wed Nov 06 01:39:23.235478 2019] [mpm_prefork:not$AH00558: apache2: Could not reliably determine the$[Wed Nov 06 01:39:23.571129 2019] [mpm_prefork:not$[Wed Nov 06 01:39:23.571231 2019] [core:notice] [p$
OK lets add back (if you removed them) the long path:
mkdir /ACME-challenges/.well-known/
mkdir /ACME-challenges/.well-known/acme-challenge/
and try:
certbot certonly --webroot -w /ACME-challenges/ -d voidcitymc.com --staging
Same error as before
OK rem out, or delete, the Alias line added to the /etc/apache2/apache2.conf file.
restart apache
try again:
Again it’s same error as before
Do you think the issue is with my domain names nameservers?
OMG! IMPOSSIBLE!
No.
Our test-file worked!
OK WE USE A BIGGER HAMMER!
We go --standalone
Not sure at this point
It’s a 3 step process (that can be integrated into a single statement - but we’ll do that part later).
Step 1. stop Apache
systemctl stop apache2
Step 2. get cert using temporary certbot webserver
certbot certonly --standalone -d voidcitymc.com --staging
Step 3. restart Apache
systemctl start apache2
I got the certificate:)
ABOUT TIME!
The downside is webservice stops during that minute (once every 60 days)
Now let’s get a real cert and roll that up into one line and ensure renewals are good to go…
Can I use cron for renewals?
certbot will handle all that (cron/system) for us
Good, when I visit https://voidcitymc.com it doesn’t seem to work though
we haven’t installed the cert yet - hold on
plus that was a staging cert - not valid in the real world
Ah the —staging argument
Next step: Roll those 3 steps into one (real) step:
certbot certonly --standalone -d voidcitymc.com --pre-hook "systemctl stop apache2" --post-hook "systemctl start apache2"
