Cant create a certificate - Port 80 issue
My domain is: nomadus.duckdns.org
I ran this command: certbot certonly --standalone -d nomadus.duckdns.org
Requesting a certificate for nomadus.duckdns.org
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile C:\Certbot\log\letsencrypt.log or re-run Certbot with -v for more details.
The only i can say that i know for sure is that i have an active port fowarding for 80
as well an active rule in my windows firewall for the inbound. So i have no clue on why i have that issue.
There's a chance that i have made something wrong with those steps, but so far i review it several times and doesn't appear to be wrong.
My web server is (include version): I would love to tell, but i have no idea.
The operating system my web server runs on is (include version): Windows 10
My hosting provider, if applicable, is: I would say duckdns
I can login to a root shell on my machine (yes or no, or I don't know): i dont know
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): control panel in like Command Prompt? cuz no idea.
**The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):**certbot 1.24.0
Hello @DarkNomadus, welcome to the Let's Encrypt community. :slightly_smiling_face:
Well I do not believe that HTTP Port 80 is open.
$ curl -I http://nomadus.duckdns.org/.well-known/acme-challenge/FP6atzuxSAl_OacMUWPiPdRZz6CRjJ8CYFDU2_s0ZkM
curl: (28) Failed to connect to nomadus.duckdns.org port 80 after 129867 ms: Connection timed out
And
$ nmap -Pn nomadus.duckdns.org
Starting Nmap 7.80 ( https://nmap.org ) at 2022-11-19 22:51 UTC
Nmap scan report for nomadus.duckdns.org (212.225.225.91)
Host is up.
rDNS record for 212.225.225.91: 91.red.225.225.212.procono.es
All 1000 scanned ports on nomadus.duckdns.org (212.225.225.91) are filtered
Nmap done: 1 IP address (1 host up) scanned in 201.93 seconds
Best Practice - Keep Port 80 Open
@DarkNomadus,
Please find your IP Address with https://ifconfig.co/ in a Web Browser as you stated you are running on
On the machine that
Also (just informational)
Spins up itself as a temporary web server for getting the certificate.
