Can’t generate SSL certificate with Laravel project and nginx
www.destinydev.eu
I ran this command and It produced this output:
certbot --nginx
nginx/1.19.2
Archlinux
Myself
no, only CLI
certbot 1.7.0
The error:
Challenge failed for domain www.destinydev.eu
http-01 challenge for www.destinydev.eu
2020/08/28 16:10:16 [notice] 658#658: signal process started
Some challenges have failed
Domain: www.destinydev.eu
Type: connection
Detail: Fetching
http://www.destinydev.eu/.well-known/acme-challenge/lsPnmsNYZKLOuJRzquW2kcXBY4r6rmiA21LIABZsehU:
More:
it appears that certbot is trying to access ".well-known/acme-challenge/lsPnmsNYZKLOuJRzquW2kcXBY4r6rmiA21LIABZsehU" but it not exist.
The script dont make folders and file in the public folder and i dont know why.
No no, you're not reading the error correctly. You say "it does not exist", the Let's Encrypt validation server (and so do I) says "I can't connect to your site at all".
I can't ping it, I can't connect to port 80 nor port 443, but strangely enough it does reply to a traceroute..
Seems to me you've got some firewall blocking access to port 80 (and 443).
I can’t ping it
this is normal. For security, I have prohibited responses to pings.
But port 80 and 443 are open
Not from my endpoint. And looking at the error presented by the Let's Encrypt validation server, neither from their endpoint.
In essence your site isn't reachable at all. See also: https://downforeveryoneorjustme.com/destinydev.eu?proto=http&www=1
if port 80 was not open, we could not access the site in http. However, it is possible.
look my website on your browser.
Part of my iptable:
-A TCP -p tcp -m tcp --dport 80 -j ACCEPT
-A TCP -p tcp -m tcp --dport 443 -j ACCEPT
I did................ Your site is NOT accessible. Like I said, it is down.. I'm saying it, Let's Encrypt is saying it, a third (or even fourth) party (see the URL I posted earlier) is saying it..
I don't know what is blocking access, but something is. Could even be regional.
:sweat:
You said you cant access at this url http://www.destinydev.eu/ ?
So why do I get there ?
Hi @Astriaporta
your website doesn't answer - see https://check-your-website.server-daten.de/?q=destinydev.eu - only timeouts.
Not http, not https, not http + /.well-known/acme-challenge/random-filename:
http://destinydev.eu/ 88.127.171.222 -14 10.053 T
Timeout - The operation has timed out
http://www.destinydev.eu/ 88.127.171.222 -14 10.004 T
https://destinydev.eu/ 88.127.171.222 -14 10.040 T
https://www.destinydev.eu/ 88.127.171.222 -14 10.027 T
http://destinydev.eu/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 88.127.171.222 -14 10.023 T
Visible Content:
http://www.destinydev.eu/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 88.127.171.222 -14 10.033 T
Visible Content:
If online tools can't check your domain, Letsencrypt may have the same problem.
Change that.
Correct.
I don't know. Probably because you're closer to the host, location wise speaking? Whitelisted? No idea..
:thinking: it’s probably a country restriction. I’m in France.
But it seems strange to me because others can do it
