Can somebody help me
My domain is: joomla4.mytechsite.gq
It produced this output: Unable to find corresponding HTTP vhost; Unable to create one as intended addresses conflict; Current configuration does not support automated redirection
What would you like to do?
2: Renew & replace the certificate (may be subject to CA rate limits)
Deploying certificate
Successfully deployed certificate for joomla4.mytechsite.gq to /etc/apache2/sites-enabled/joomla4.conf
Failed redirect for joomla4.mytechsite.gq
Unable to set the redirect enhancement for joomla4.mytechsite.gq.
NEXT STEPS:
  • The certificate was saved, but could not be installed (installer: apache). After fixing the error shown below, try installing it again by running:
    certbot install --cert-name joomla4.mytechsite.gq
My web server is (include version): Ubuntu 22.04 (fully updated and upgraded)
The operating system my web server runs on is (include version): Apache/2.4.52 (Ubuntu)
My hosting provider, if applicable, is: VPS Oracle
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.21.0
Hi @UncleSam, and welcome to the LE community forum :slight_smile:
You need to correct your Apache configuration.
I'd start with the output of:
sudo apachectl -t -D DUMP_VHOSTS
OK I ran the command as you suggested and the output is as follows:
`sudo apachectl -t -D DUMP_VHOSTS`
ubuntu@instance-20230417-0416:~$ sudo apachectl -t -D DUMP_VHOSTS
VirtualHost configuration:
*:443                  joomla3.mytechsite.gq (/etc/apache2/sites-enabled/joomla3b-le-ssl.conf:2)
*:80                   is a NameVirtualHost
         default server 132.145.57.84 (/etc/apache2/sites-enabled/000-default.conf:1)
         port 80 namevhost 132.145.57.84 (/etc/apache2/sites-enabled/000-default.conf:1)
         port 80 namevhost joomla3.mainsite.tk (/etc/apache2/sites-enabled/joomla3.conf:1)
                 alias www.joomla3.mainsite.tk
         port 80 namevhost joomla3.mytechsite.gq (/etc/apache2/sites-enabled/joomla3b.conf:1)
                 alias www.joomla3.mytechsite.gq
         port 80 namevhost joomla4.mytechsite.gq (/etc/apache2/sites-enabled/joomla4.conf:1)
                 alias www.joomla4.mytechsite.gq
         port 80 namevhost oracle.mainsite.tk (/etc/apache2/sites-enabled/oracle.conf:1)
                 alias www.oracle.mainsite.tk
         port 80 namevhost phpmyadmin.mainsite.tk (/etc/apache2/sites-enabled/phpmyadmin.conf:1)
                 alias www.phpmyadmin.mainsite.tk
Do you see anything in the above output that stands out to be the culprit.
I have quite a few subdomains on the server but for some reasons joomla3, & jooml4 are mixed up. Joomla3 works as expected but joomla4 seems to be a real problem.
The relevant sites are:
https://joomla3.mytechsite.gq
https://joomla4.mytechsite.gq
https://phpmyadmin.mainsite.tk
https://oracle.mainsite.tk
I could redo the joomla4 config but before I do I'll wait for your opinion.
Kind regards,
Can I also mention that Joomla4 is not a risky site. It is completely blank at the moment so the warning you might get is standard Firefox warning message because there is no certificate attached yet..
Thank you.
Let's have a look at this file:
OK here it is:
<VirtualHost *:80>
    ServerName joomla4.mytechsite.gq
    ServerAlias www.joomla4.mytechsite.gq
    ServerAdmin webmaster@mytechsite.gq
    DocumentRoot /var/www/joomla4.mytechsite.gq
    SSLEngine on
    ErrorLog ${APACHE_LOG_DIR}/joomla4-error.log
    CustomLog ${APACHE_LOG_DIR}/joomla4-access.log combined
    <Directory /var/www/joomla4.mytechsite.gq>
        Options -Indexes +FollowSymLinks
        AllowOverride All
    </Directory>
	<IfModule dir_module>
    	# DirectoryIndex index.php index.html index.shtml default.html main.html
	</IfModule>
</VirtualHost>
You should remove that. VirtualHosts for port 80 do not handle SSL
I don't know that it will fix the problem but it is wrong and unusual to see.
Once removed try this from the error message
No luck. This is what I get:
ubuntu@instance-20230417-0416:~$ sudo systemctl reload apache2
ubuntu@instance-20230417-0416:~$ sudo certbot install --cert-name joomla4.mytechsite.gq
Could not install certificate
Could not reverse map the HTTPS VirtualHost to the original
Please show this file:
Here it is:
<IfModule mod_ssl.c>
<VirtualHost *:443>
    ServerName joomla3.mytechsite.gq
    ServerAlias www.joomla3.mytechsite.gq
    DocumentRoot /var/www/joomla3.mytechsite.gq
    ErrorLog ${APACHE_LOG_DIR}/joomla3b-error.log
    CustomLog ${APACHE_LOG_DIR}/joomla3b-access.log combined
    <Directory /var/www/joomla3.mytechsite.gq>
        AllowOverride All
    </Directory>
	</IfModule>
SSLCertificateFile /etc/letsencrypt/live/joomla3.mytechsite.gq/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/joomla3.mytechsite.gq/privkey.pem
</VirtualHost>
</IfModule>
This file was created automatically by certbot so I know I can't change it. Joomla3 works OK as far as I can see.
Joomla4 had a previous certicate by zeroSSL but I have revoked it. It still shows here for some reasons:
For joomla3, there are only the correct entries here:
I know I made a real hash by not selecting both J3 and J4 at the time os certificate issuance but now how do I reverse the error.
Thanks for your persevering on this.
This might be a better output:
<VirtualHost *:443>
        AllowOverride All
    </Directory>
	</IfModule>
</VirtualHost>
</IfModule>
The best output is to use 3 backticks before and after the Apache config like
apache config
Use the same 3 backtick method to show results of this
sudo certbot certificates
Depending on the output of:
you may be able to copy the file:
as:
/etc/apache2/sites-available/joomla4-le-ssl.conf
[then edit the new file and change the "3"s/"3b"s to "4"s]
and then enable it and restart Apache.
Done it and it works. Thank you very much indeed. Now I can document the entire process for future reference.
Just to test your suggestion of 3 dots I am posting this but it is not really part of the solution or question:
Found the following certs:
  Certificate Name: joomla3.mytechsite.gq
    Serial Number: 342cde912c824e8d72e6b825d62a8c28e90
    Key Type: RSA
    Domains: joomla3.mytechsite.gq
    Expiry Date: 2023-08-02 01:22:08+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/joomla3.mytechsite.gq/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/joomla3.mytechsite.gq/privkey.pem
  Certificate Name: joomla4.mytechsite.gq
    Serial Number: 4fb6c0868fad4ad922e628d361990033e89
    Key Type: RSA
    Domains: joomla4.mytechsite.gq
    Expiry Date: 2023-08-02 01:29:20+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/joomla4.mytechsite.gq/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/joomla4.mytechsite.gq/privkey.pem
Hope it does show as proper unformatted quote.
    Key Type: RSA
    Key Type: RSA
It seems to work. The term backticks might be new to some but it is on a key on the left of number 1 on my keyboard.
FYI for new users here.
It is actually 3 backticks but you are right we don't need that info anymore. Thanks
Number one google search result for backtick :slight_smile:
