Can i get certs for multi level wildcard
My domain is: ad.marcuse.net.au and marcuse.net.au
My hosting provider, if applicable, is: cloudflare
i got Letsencrypt in a docker = https://hub.docker.com/r/linuxserver/letsencrypt/
Hello,
i been trying for awhile now to get certs for multi level domain and i just cant find a solution.
im trying to access servers and applications within both primary and sub domains.
E.g
server1.ad.marcuse.net.au
and
server.marcuse.net.au
can someone please help me get the certs to work on both.
i dont mind switching out of the docker if thats the only way.
thank you
Multi-level wildcards don’t exist at all - either don’t use wildcards or use a certificate with multiple wildcard names, e.g.:
*.marcuse.net.au
*.ad.marcuse.net.au
I tried to make the multiple wildcard but it came up with errors.
TZ=Austrlia/Sydney
URL=marcuse.net.au
SUBDOMAINS=wildcard
EXTRA_DOMAINS=*.ad.marcuse.net.au
ONLY_SUBDOMAINS=false
DHLEVEL=2048
VALIDATION=dns
DNSPLUGIN=cloudflare
EMAIL=ben@marcuse.net.au
STAGING=
2048 bit DH parameters present
SUBDOMAINS entered, processing
Wildcard cert for marcuse.net.au will be requested
EXTRA_DOMAINS entered, processing
Extra domains processed are:  -d *.ad.marcuse.net.au
E-mail address entered: ben@marcuse.net.au
dns validation via cloudflare plugin is selected
Different validation parameters entered than what was used before. Revoking and deleting existing certificate, and an updated one will be created
Generating new certificate
Plugins selected: Authenticator dns-cloudflare, Installer None
dns-01 challenge for ad.marcuse.net.au
dns-01 challenge for marcuse.net.au
Unsafe permissions on credentials configuration file: /config/dns-conf/cloudflare.ini
Waiting 10 seconds for DNS changes to propagate
Challenge failed for domain ad.marcuse.net.au
Challenge failed for domain marcuse.net.au
Domain: ad.marcuse.net.au
Type:   unauthorized
Detail: Incorrect TXT record "ca3-285091a9f3c345b7a5640c9d15f690d2"
found at _acme-challenge.ad.marcuse.net.au
Domain: marcuse.net.au
Type:   unauthorized
found at _acme-challenge.marcuse.net.au
Type:   unauthorized
ERROR: Cert does not exist! Please see the validation error above. Make sure you entered correct credentials into the /config/dns-conf/cloudflare.ini file.
_acme-challenge.ad.marcuse.net.au. 599 IN CNAME marcuse.net.au.
Can you comment on why you have this CNAME’d? It’ll be the cause of your issue.
its my wildcard for my dns.
That’s not a great idea because it affects all record types (in this instance, it messes up the TXT records).
I think what you probably want is a wildcard A record pointing to the same IP as your base domain.
Assuming Cloudflare implements empty non-terminals and wildcards in the standard way, any wildcard is a bad idea, because it will temporarily cease to exist while the _acme-challenge TXT records exist.
Edit: I should have said, relying entirely on one wildcard would be a bad idea. Using them carefully would work.
Can you please tell me how i should setup cloudflare then ?
I don’t know how you want to set it up.
You could add two wildcard A records, “*” and “*.ad”, and remove the wildcard CNAME record.
Do you really need wildcard DNS records, or wildcards in your certificates?
You know that Cloudflare’s cheaper plans don’t support proxying wildcard records, right?
And that, if you do proxy things, Cloudflare’s default certificate is only for marcuse.net.au and *.marcuse.net.au?
everything under *.ad is internal only.
im using the letsencrypt docker which allows proxy within
so i changed my a records to be what u advised.
im still getting an error:
You’ve created several certificates recently.
Is that web server configured to use one of them?
Does it need to be reloaded or restarted?
I get a “connection refused” error trying to connect to https://pfsense.ad.marcuse.net.au/, FYI.
i rebooted the machine what is running the letsencrypt.
i reloaded and still getting certificate error.
i will wait an hr and see if it works.
accessing all *.ad is internal so that is why you cant access it https://pfsense.ad.marcuse.net.au
How many domains do you need this to work on? 2 or more?
