CAA error for issuing certificate with CN=www.cyber.army.mil
My domain is: www.cyber.army.mil
dig CAA www.cyber.army.mil
; <<>> DiG 9.10.6 <<>> CAA www.cyber.army.mil
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 58233
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;www.cyber.army.mil. IN CAA
;; ANSWER SECTION:
www.cyber.army.mil. 3600 IN CNAME www.armypw.army.mil.edgekey.net.
www.armypw.army.mil.edgekey.net. 300 IN CNAME e16905.dscb.akamaiedge.net.
We were told by LE that there are CAA errors on domains for certificate with CN=www.cyber.army.mil. The issue is that the actual tests for CAA check work fine for the domain. The error I see in the API response from LE is below. Can we get more information on this error? How can I validate what exactly is the CAA error here? We had seen something similar with .mil domain in past.
error:
  code: le-certificate-error
  message: Error getting certificate and trust chain from Let's Encrypt
  formatString: 'Error: {0}, Detail: {1}'
  formatParameters:
  - Error getting certificate and trust chain from Let's Encrypt
  - POST to https://acme-v01.api.letsencrypt.org/acme/new-cert failed.
  timestamp: 2018-11-16T21:22:47z
Why would you think the error signifies a CAA error?
It would have been helpful if you also gave the command for the issuing of the certificate, not just the dig command.
In the past, Let’s Encrypt was not allowed to issue certificates for .mil domains at all, but now that rule has changed and there are a number of .mil certificates issued by Let’s Encrypt.
https://crt.sh/?Identity=%.mil&iCAID=16418
As @Osiris mentioned, it would be helpful to see the exact command and error message, or whatever communication you’ve previously had from Let’s Encrypt staff about CAA problems.
