CAA record for letstalk.milton.ca prevents issuance
My domain is: letstalk.milton.ca
I ran this command: sudo certbot certonly --force-renewal --webroot -w /var/www -d "letstalk.milton.ca"
http-01 challenge for letstalk.milton.ca
Using the webroot path /var/www for all unmatched domains.
Failed authorization procedure. letstalk.milton.ca (http-01): urn:ietf:params:acme:error:caa :: CAA record for letstalk.milton.ca prevents issuance
    Domain: letstalk.milton.ca
    Type: None
    Detail: CAA record for letstalk.milton.ca prevents issuance
My web server is (include version): Openresty
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.26.1
I am trying to get a certificate for this domain but i am getting the above caa failed issuance error . I dont know how to fix the issue . Please help me to get this fixed .
Please don't use this option. When something is wrong with issuance, it doesn't force issuance by suddenly making the error go away. It however can cause you to run into rate limit if you keep forcing issuance, but the problem is for example with installing a certificate. Therefore, this option is best not to be used.
That said, the problem is with the CAA record of milton.ca:
milton.ca. 300 IN CAA 0 issue "entrust.net"
When quering the CAA records to check if Let's Encrypt is allowed issuance for the hostname, it will check the parent DNS zone of the hostname if there is no CAA found.
Three solutions exist:
  • Change the CAA record for milton.ca zone to also include Let's Encrypt, or;
  • Delete the CAA record for milton.ca zone altogether so any CA can issue for the domain, or;
  • Add a CAA record allowing Let's Encrypt to the letstalk.milton.ca hostname.
See also the CAA documentation page from Let's Encrypt, which also links to other useful resources for it:
But the core of the issue is that if the domain is specifically configured by the DNS owner to not allow Let's Encrypt, then Let's Encrypt can't work for it.
I'm guessing, based on the fact that you don't seem to have familiarity with CAA records and that the name you give is a CNAME to another domain entirely, that you're running a service of some sort where you expect your customer to just add the CNAME to you and that you run the whole server. If that's the case:
  1. Because the rest of the certificates for this name are OV certificates from Entrust, your customer might be expecting all their certificates to be from that vendor (which is why they put the CAA record in the first place). They may prefer you to be sending them CSR files for them to get certificates for rather than you getting certificates yourself. It's probably best for you to coordinate with their IT department how they're expecting things to work.
  2. The easiest "solution" for you (though like I said whether or not your customer wants it this way may be another story) is probably for you to add your own CAA record for the name that your customer CNAMEs to (not just for this customer, but probably for all of them), allowing for "letsencrypt.org". That will allow you to automatically get a certificate from Let's Encrypt and "override" the higher-level domain record. (CAA is checked from the full domain name, and then if there's no record checking the name with the first part removed, and so forth until at the root, at which case if there's no CAA at all it's presumed to be allowed.)
Most, if not all, of that requires DNS control over (potentially) customer domains.
That probably won't scale very well.
For these types of problematic situations, have you considered also offering a subdomain of one of your business domains specifically for your customers' use?
Like:
letstalk.milton.ca.your.domain
letstalk-milton-ca.clients.your.domain
