Basic help on upgrading to ACMEv2
Hello. I’m a basic user with not much technical knowledge. I would like to upgrade my Certify the Web package to ACMEv2 and need some general guidance. I have found the Certify SSL Manager latest download on the site https://certifytheweb.com/. My question is; for it to work do I simply have to download it to my server and follow whatever instructions pop up, or will it get more technical than that such that I will need specialist input? I don’t want to get out of my depth and then find all sorts of problems arising.
My domain is: smithfieldperformance.com
My web server is (include version): Windows ISS7.0
The operating system my web server runs on is (include version): Windows Server 2016 64 bit
My hosting provider, if applicable, is: Microsoft Azure
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): Don’t Know
You should look at this announcement:
