AWS Node.js Elastic Beanstalk
My domain is: api.cyyann.com
Problem: I created a Node.js Elastic Beanstalk server on AWS with the deafult Node.js application template. I tried as much solutions as i find on the internet to install the certificate but I always got an error like this.
command i tried to run:
  • sudo /usr/local/bin/certbot-auto --nginx
Error:
With Elastic Beanstalk, you are going to have to make some careful customizations to match the exact proxy environment that AWS has created for you: https://docs.aws.amazon.com/elasticbeanstalk/latest/dg/nodejs-platform-proxy.html
Certbot isn’t able to understand how Elastic Beanstalk is setup on its own.
For instance, if the default nginx listening port is 8080 (as in that above article), you may have to run Certbot with:
--http-01-port 8080
If that’s not it, then please provide the full output of the following command:
nginx -T
Thank you, Now I receive a different error
Exiting abnormally:
File "/opt/eff.org/certbot/venv/bin/letsencrypt", line 11, in
sys.exit(main())
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py", line 1378, in main
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py", line 1140, in run
_install_cert(config, le_client, domains, new_lineage)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py", line 764, in _install_cert
path_provider.cert_path, path_provider.chain_path, path_provider.fullchain_path)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/client.py", line 507, in deploy_certificate
fullchain_path=fullchain_path)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_nginx/configurator.py", line 202, in deploy_cert
vhosts = self.choose_vhosts(domain, create_if_no_match=True)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_nginx/configurator.py", line 311, in choose_vhosts
str(self.config.https_port))]
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_nginx/configurator.py", line 359, in _vhost_from_duplicated_default
default_vhost = self._get_default_vhost(domain, allow_port_mismatch, port)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_nginx/configurator.py", line 397, in _get_default_vhost
" block for %s. Set the server_name directive to use the Nginx installer." % domain)
MisconfigurationError: Could not automatically find a matching server block for api.cyyann.com. Set the server_name directive to use the Nginx installer.
  • Unable to install the certificate
    /etc/letsencrypt/live/api.cyyann.com/fullchain.pem
    /etc/letsencrypt/live/api.cyyann.com/privkey.pem
    Your cert will expire on 2019-11-16. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot-auto
    again with the "certonly" option. To non-interactively renew all
    of your certificates, run "certbot-auto renew"
  • Your account credentials have been saved in your Certbot
You’re probably better off following the AWS documentation for configuring HTTPS on Elastic Beanstalk: https://docs.aws.amazon.com/elasticbeanstalk/latest/dg/https-singleinstance-nodejs.html
Whilst you could potentially fix the above error by adding a server_name in your nginx config, the changes (and also your certificates) are going to be wiped out every time your app is re-deployed.
The correct way to do what you are trying to do is to use Elastic Beanstalk with an AWS load balancer and a free certificate from AWS ACM, deployed to the load balaner.
Certbot wasn’t built to be used in temporary, horizontally-scaled environments like Elastic Beanstalk.
