My domain is: app.dailynclexchallenge.com
I ran this command: sudo /usr/local/bin/certbot-auto certonly -d app.dailynclexchallenge.com --webroot -w /var/www/html
It produced this output: Cleaning up challenges
Domain: app.dailynclexchallenge.com
Detail: Invalid response from
http://app.dailynclexchallenge.com/.well-known/acme-challenge/88XzSg-2ZtGvJPRAAz4r5n43gW8neQdj9TokL1JrpE8
[18.190.73.107]: “\n\n404 Not
Found\n\nNot Found
\n<p”To fix these errors, please make sure that your domain name was
My web server is (include version): Apache/2.4.41 (Amazon)
The operating system my web server runs on is (include version): Amazon Linux AMI 2018.03
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 1.1.0
It appears that the script doesn’t create a .well-known or acme-challenge directory, nor does it create the random file it checks, and thus generates a 404.
As to the insult to injury, now apparently because of the script failures I have hit Let’s Encrypt’s rate limit (which seems a bit wonky, since I’m not actually successfully creating a certificate,) and thus I cannot continue testing.
Not to sound like an old curmudgeon, but can’t a fella get a download of the certificate vs. jumping through certbot land, at least as a temporary fix?
How very frustrating.
