I’ve created a little script to automatically publish the TLSA records. Just in case someone needs it. It creates new TLSA records and adds them to DNS but is not replacing the old certificates because you should wait a few hours until they are publish to all DNS servers.
#!/bin/bash
LE=/etc/letsencrypt
LEROOT=/root/letsencrypt
LEBIN=letsencrypt-auto
NSU=/root/nsupdate.txt
cd $LEROOT
COUNT=0;
for DOMAIN in d1.tld d2.tld d3.tld
do
case $COUNT in
0 )
WEBROOT=/var/www/d1
1 )
WEBROOT=/var/www/d2
2 )
WEBROOT=/var/www/d3
WEBROOT=/var/www/d1
esac
./$LEBIN certonly -d $DOMAIN --server https://acme-v01.api.letsencrypt.org/directory -a webroot --webroot-path $WEBROOT --renew-by-default --rsa-key-size 4096
echo $DOMAIN $WEBROOT
let "COUNT += 1"
done
/etc/init.d/nginx stop
./$LEBIN certonly -d mx01.d1.tld --server https://acme-v01.api.letsencrypt.org/directory --renew-by-default
/etc/init.d/nginx start
KEY=`openssl x509 -in $LE/live/mx01.d1.tld/fullchain.pem -outform DER |openssl sha256|awk '{print $2}'`
KEY2=`openssl x509 -in $LE/live/d1.tld/fullchain.pem -outform DER |openssl sha256|awk '{print $2}'`
for DOMAIN in d1.tld mx01.d1.tld
do
cd $LE/live/$DOMAIN
rm -f *
FULLPATH=`ls -tr $LE/archive/$DOMAIN/cert*.pem|head -n -1|tail -1`
CERT=`basename $FULLPATH`
NUMBER=`echo $CERT|sed 's/cert//;s/.pem//'`
ln -s ../../archive/$DOMAIN/cert$NUMBER.pem cert.pem
ln -s ../../archive/$DOMAIN/chain$NUMBER.pem chain.pem
ln -s ../../archive/$DOMAIN/fullchain$NUMBER.pem fullchain.pem
ln -s ../../archive/$DOMAIN/privkey$NUMBER.pem privkey.pem
done
/etc/init.d/dovecot restart
/etc/init.d/postfix restart
echo ttl 60 > $NSU
echo update add _25._tcp.mx01.d1.tld. IN TLSA 3 0 1 $KEY >> $NSU
echo update add _443._tcp.d1.tld. IN TLSA 3 0 1 $KEY2 >> $NSU
echo send >> $NSU
nsupdate -l $NSU
Replacing the old certificates require another script to run a few hours later:
#!/bin/bash
LE=/etc/letsencrypt
NSU=/root/nsupdate_del.txt
do
cd $LE/live/$DOMAIN
rm -f *
FULLPATH=`ls -tr $LE/archive/$DOMAIN/cert*.pem|tail -1`
done
echo ttl 60 > $NSU
echo update delete _25._tcp.mx01.d1.tld >> $NSU
echo update delete _443._tcp.d1.tld >> $NSU
echo send >> $NSU
nsupdate -l $NSU
/etc/init.d/nginx restart
So are there any suggestion for improvement?
