Automatice renew not working, certbot.renew.timer missing
My domain is: wo-lar.com
certbot is installed and certificate is ok. I can also do the try run to renew.
But the timer is missing
systemctl list-timers -all
NEXT                         LEFT       LAST                         PASSED    UNIT                         ACTIVATES
Fri 2022-12-30 18:12:58 CET  26min left Fri 2022-12-30 16:53:15 CET  53min ago dnf-makecache.timer          dnf-makecache.service
Sat 2022-12-31 00:00:00 CET  6h left    Fri 2022-12-30 00:00:01 CET  17h ago   unbound-anchor.timer         unbound-anchor.service
Sat 2022-12-31 10:08:52 CET  16h left   Fri 2022-12-30 10:08:52 CET  7h ago    systemd-tmpfiles-clean.timer systemd-tmpfiles-clean.service
n/a                          n/a        n/a                          n/a       certbot-renew.timer          certbot-renew.service
httpd-2.4.37-51.module+el8.7.0+1059+126e9251.x86_64
Rocky Linux 8
kernel-4.18.0-425.3.1.el8.x86_64
NA
Yes
No
certbot --version
How can I fix this?
Thanks, Wolfgang
How did you install Certbot?
NB: the question is asking about the output of that command, not literally type over which command you would need to use. :wink:
Did you install, then remove, then reinstall certbot [via multiple methods]?
I assume you installed Certbot from EPEL8, which is packaged by third-party volunteers and not the Certbot team. You are free to install Certbot this way but is not the recommended installation method.
My understanding is that the Certbot package from EPEL is supposed to enable the renewal timer by default.
Originally, it did not, for some Fedora policy reason.
Then, Certbot was included in the list of packages that would be enabled by default.
Then, there was a bug which prevented it from being enabled properly, but it was fixed.
I tried installing Certbot from EPEL on CentOS 7, RockyLinux 8 and AlmaLinux 8, and the timer was not enabled by default on any of them. So I assume something is not working as intended and somebody probably needs to file a bug with EPEL.
Anyway, this should do the trick:
systemctl enable --now certbot-renew.timer
Thank you!
That solved the problem.
Best regards,
