Automatic way of renewing certificates for website.com and *.website.com
I have a web server on which I apply different rewrite rules in order to redirect all http(s)://*.website.com requests to the same URL : https://website.com. Everything is working fine as expected.
Now, I would like to make the renewing of certificates (built by letsencrypt) in an automatic way.
Unfortunately, for the moment, I have to do it manually and the ideal is to do it by a simple script called from a crontab (I would like to renew certificates every 2 months).
Currently, I am using the following script certbot-auto (from https://github.com/certbot/certbot/blob/master/certbot-auto) this way :
sudo certbot certonly --manual -d *.website.com -d website.com --agree-tos --no-bootstrap --manual-public-ip-logging-ok --preferred-challenges dns-01 --server https://acme-v02.api.letsencrypt.org/directory
Here the output I get from this command :
Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/website.com.conf with version 0.31.0 of Certbot. This might not work.
dns-01 challenge for website.com
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you're running certbot in manual mode on a machine that is not
your server, please ensure you're okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: Y
Please deploy a DNS TXT record under the name
_acme-challenge.website.com with the following value:
j-iC2Fywptdjn_MX4UQCTzDJ5FiuyyZiosVaZYTZxNA
Before continuing, verify the record is deployed.
Press Enter to Continue
eO1eVTi4cPTpZYcuAkrqqYpRcPIobayhPawvtLNqBpU
(This must be set up in addition to the previous challenges; do not remove,
replace, or undo the previous challenge tasks yet. Note that you might be
asked to create multiple distinct TXT records with the same name. This is
permitted by DNS standards.)
   /etc/letsencrypt/live/website.com/fullchain.pem
   /etc/letsencrypt/live/website.com/privkey.pem
   Your cert will expire on 2020-06-29. To obtain a new or tweaked
   version of this certificate in the future, simply run certbot-auto
   again. To non-interactively renew *all* of your certificates, run
   "certbot-auto renew"
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-leyed.
I wonder if there is a way to automate this registration of TXT fields or if there is another way to launch a simple command or script in crontab (executed every 2 months) to avoid all these manual operations ?
you'd need to use dns script to update dns for you, can't say much about without site name
Yes, i do have a python script ready to deploy a DNS TXT record under the name
_acme-challenge.website.com but the issue i am facing here is when i have to come back to the terminal and "press enter" to verify the record is deployed.
https://eff-certbot.readthedocs.io/en/stable/using.html#pre-and-post-validation-hooks
certbot certonly --manual --preferred-challenges=dns --manual-auth-hook /path/to/dns/authenticator.sh --manual-cleanup-hook /path/to/dns/cleanup.sh -d secure.example.com
change parameter as needed
That certbot-auto script was deprecated and removed some years ago. Please update your Certbot using one of the (semi-)supported methods. See https://certbot.eff.org/ for more info.
is the command i am currently using for version "certbot 2.8.0". I am looking for ways to automate this renewal process through a script.
Are you sure?:
Here Certbot claims it's version 0.31.0, not 2.8.0.
See @orangepizza s post above.
