Authorization failed when running wacs.exe
My domain is: fastpassmanager.goering.de [5.10.178.170]
[INFO] A simple Windows ACMEv2 client (WACS)
[INFO] Software version 200.0.6959.25723 (RELEASE)
[INFO] IIS version 7.5
[INFO] Please report issues at https://github.com/PKISharp/win-acme
N: Create new certificate
M: Create new certificate with advanced options
L: List scheduled renewals
R: Renew scheduled
S: Renew specific
A: Renew all
C: Cancel scheduled renewal
X: Cancel all scheduled renewals
T: (Re)create scheduled task
I: Import scheduled renewals from WACS/LEWS 1.9.x
Q: Quit
Please choose from the menu: n
[INFO] Running in mode: Interactive, Simple
1: Single binding of an IIS site
2: SAN certificate for all bindings of an IIS site
3: SAN certificate for all bindings of multiple IIS sites
4: Manually input host names
C: Cancel
Which kind of certificate would you like to create?: 1
1: fastpassmanager.goering.de (SiteId 2)
C: Cancel
Choose binding: 1
[INFO] Target generated using plugin IISBinding: fastpassmanager.goering.de
[INFO] Authorize identifier: fastpassmanager.goering.de
[INFO] Authorizing fastpassmanager.goering.de using http-01 validation (SelfHos
ting)
[EROR] Authorization result: invalid
[EROR] Create certificate failed: Authorization failed
My web server is (include version): IIS Server 7.5
The operating system my web server runs on is (include version): Windows Server 2008 R2
I can login to a root shell on my machine (yes or no, or I don’t know): yes, admin priviliges are provided
Thanks in advance!
Do they have a support channel?
IIS v7.5 doesn't support SNI (not sure if this adds to the problem)
Hi @Bancroft
your main configuration is ok ( https://check-your-website.server-daten.de/?q=fastpassmanager.goering.de ):
• http://fastpassmanager.goering.de/
5.10.178.170 200 0.077 H
• https://fastpassmanager.goering.de/
5.10.178.170 200 1.603 N
Certificate error: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
• http://fastpassmanager.goering.de/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
5.10.178.170 404 0.103 A
Not Found
Port 80 is open, the critical subdirectory /.well-known/acme-challenge is visible.
But (a standard IIS problem): Are files without extension allowed?
Find your webroot, create the two subdirectories /.well-known/acme-challenge, there a text file (file name 1234) without extension.
Then try to load this file via
http://fastpassmanager.goering.de/.well-known/acme-challenge/1234
PS: If this doesn’t work, you need a config file in /.well-known:
<configuration>
    <system.webServer>
        <staticContent>
            <mimeMap fileExtension="." mimeType="text/plain" />
        </staticContent>
    </system.webServer>
</configuration>
That allows IIS to server files without extension.
thanks for the quick response!
I created the subdirectories .wellknown and /acme-challenge and created a textfile without extension. I also added extensionless to the mimetypes.
When acessing the file via localhost directly on the server everything works properly. However, when i try to access the file using faspassmanager.goering.de i get an 404 error.
Did you create these subdirectories in your webroot?
Perhaps
C:\InetPub\wwwroot
but this may be another path?
Yes, the file is currently present under the path
C:\inetpub\wwwroot\well-known\acme-challenge
What i managed to find out is that i currently have to websites:
  1. Default Website
  2. fastpassmanager.goering.de
I added the virtual directory C:\inetpub\wwwroot\well-known with Alias .well-known to the default website and suddenly the file is accessible!
Could this be the problem: That the default website gets triggered instead of the fastpassmanager.goering.de?
You must use the webroot of fastpassmanager, not the default webroot (if you have two webserver).
That should be .well-known
[with a dash]
And this one is missing the "."
When creating folders that start with a dot…
In some older Windows systems you may have to also include a dot after the folder name.
mkdir c:\inetpub\.well-known.
mkdir c:\inetpub\.well-known\acme-challenge
This isn't relevant if he creates a virtual directory with C:\inetpub\wwwroot\well-known\acme-challenge as path.
Yes, exactly. I created a virtual directory with C:\inetpub\wwwroot\well-known\acme-challenge.
The file is accessible now with https://fastpassmanager.goering.de/.well-known/acme-challenge/1234
Any ideas on how to progress now?
But not via http. Letsencrypt needs the file via http.
So a http / port 80 binding is required.
Redirect all http to https.
LE will follow the redirection and should find the file in that folder
