I’m trying to install certificate with this command:
sudo certbot --nginx -d bankofsoftware.com -d www.bankofsoftware.com
http-01 challenge for bankofsoftware.com
http-01 challenge for www.bankofsoftware.com
Failed authorization procedure. bankofsoftware.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: The key authorization file from the server did not match this challenge [iMz-rheG9C6ZD0WO8kkxZG7vl5-IW7v93lYE1QdKzdU.5Z9XTwxEQWb5ZnlUsMpWZEm2RWU_qCT-y6pkpPFdMuA] != [iMz-rheG9C6ZD0WO8kkxZG7vl5-IW7v93lYE1QdKzdU.-f_daEYxVOFls4aupfol2f4PA8ikqBUw-4tU6dotcK8]
Domain: bankofsoftware.com
Detail: The key authorization file from the server did not match
this challenge
I have no idea why this wouldnt work
