AttributeError: module 'acme.challenges' has no attribute 'TLSSNI01'
EDIT: i solve this by removing the package installed with apt: sudo apt remove python3-certbot-nginx and installing with pip: sudo pip3 install certbot-nginx
geeknoon.com
sudo certbot --nginx
An unexpected error occurred:
AttributeError: module ‘acme.challenges’ has no attribute ‘TLSSNI01’
nginx version: nginx/1.17.10 (Ubuntu)
Ubuntu 20.04 LTS x86_64
AWS ec2
certbot 0.40.0
the end of log file:
    2020-05-10 00:52:21,429:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/4481359547 HTTP/1.1" 200 801
2020-05-10 00:52:21,429:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 10 May 2020 00:52:21 GMT
Content-Length: 801
Boulder-Requester: 85727446
Replay-Nonce: 0101gyM0kUDUck74wQs8Xeov2rKa17A6kH2YQ4KrjKoHUQU
X-Frame-Options: DENY
"identifier": {
"type": "dns",
"value": "blogserver.geeknoon.com"
"status": "pending",
"expires": "2020-05-17T00:43:58Z",
"challenges": [
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/4481359547/NjHyVg",
"token": "z9BN_TAI63Qf_mUGPhejTFPHhO-dZiPMRXE7pN0qkCs"
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/4481359547/UX3MZw",
"type": "tls-alpn-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/4481359547/3Le33g",
2020-05-10 00:52:21,429:DEBUG:acme.client:Storing nonce: 0101gyM0kUDUck74wQs8Xeov2rKa17A6kH2YQ4KrjKoHUQU
2020-05-10 00:52:21,430:INFO:certbot.auth_handler:Performing the following challenges:
2020-05-10 00:52:21,430:DEBUG:certbot.log:Exiting abnormally:
File "/usr/bin/certbot", line 11, in <module>
load_entry_point('certbot==0.40.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1382, in main
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1132, in run
new_lineage = _get_and_save_cert(le_client, config, domains,
File "/usr/lib/python3/dist-packages/certbot/main.py", line 121, in _get_and_save_cert
File "/usr/lib/python3/dist-packages/certbot/client.py", line 417, in obtain_and_enroll_certificate
File "/usr/lib/python3/dist-packages/certbot/client.py", line 348, in obtain_certificate
File "/usr/lib/python3/dist-packages/certbot/client.py", line 396, in _get_order_and_authorizations
authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 62, in handle_authorizations
achalls = self._choose_challenges(authzrs)
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 206, in _choose_challenges
self._get_chall_pref(authzr.body.identifier.value),
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 221, in _get_chall_pref
plugin_pref = self.auth.get_chall_pref(domain)
File "/usr/lib/python3/dist-packages/certbot_nginx/configurator.py", line 1110, in get_chall_pref
return [challenges.HTTP01, challenges.TLSSNI01]
2020-05-10 00:52:21,431:ERROR:certbot.log:An unexpected error occurred:
Ubuntu 20.04 currently has incompatible versions of the python3-certbot-nginx and python3-acme packages.
There’s a bug open and they’re working on fixing it.
Your solution worked for now, but in the long term, mixing pip and apt packages isn’t recommended. As they get updated in the future, it might create new compatibility problems!
