Apache Running at 100% - Certbot Unable To Renew Certificate
I am using LetEncrypt on my mail server and have been for almost a month now.
I am now no longer able to access my webmail website as the certificate needs to be renewed.
When I try to renew using certbot the process fails with:
“Attempting to renew cert from /etc/letsencrypt/renewal/mail.mydomain.com.conf produced an unexpected error: Failed authorization procedure. mail.mydomain.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to ... for tls-sni-01 challenge. Skipping.”
I have confirmed by IP is correct and 443 is forwarded to my mail server correctly.
Help…
(not for public)
certbot renew
certbot renew
Processing /etc/letsencrypt/renewal/mail.mydomain.com.conf
tls-sni-01 challenge for mail.mydomain.com
Waiting for verification…
Attempting to renew cert from /etc/letsencrypt/renewal/mail.mydomain.com.conf produced an unexpected error: Failed authorization procedure. mail.mydomain.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to 180.181.172.135:443 for tls-sni-01 challenge. Skipping.
/etc/letsencrypt/live/mail.mydomain.com/fullchain.pem (failure)
    Domain: mail.mydomain.com
    Type: connection
    Detail: Failed to connect to ?.?.?.?:443 for tls-sni-01
    challenge
Debian GNU/Linux 8
Server version: Apache/2.4.10 (Debian)
N/A
Yes
No
Fixed.
Apache was hung at 100% and I was unable to stop it.
I disabled the service from starting at boot and restarted the server.
Upon restart Apache was not running and the “certbot renew” command worked.
After reenabling apache at startup and rebooting the server all the children are playing nicely again.
I suspect that Apache @ 100% was due to the certificate being expired and I do wonder why the cron job failed to renew it. Running the cron command manually works…
Guess I just need to see what happens in 90 days.
explain reasoning?
When you restarted Apache you still had an expired certificate however the usage was not at 100%?
Sorry it's just that too many people on this forum assume the certificate are the root cause of their issues without investigation
Andrei
Highly unlikely--Apache will happily serve an expired certificate (as it doesn't have any concept of certificate validity anyway). Look for the problem elsewhere on your server, if you care to troubleshoot further. But yes, Apache being stuck at 100% would likely prevent or delay it from responding to connection requests, which would cause validation to fail.
...or probably closer to 60 days, which is when the renewal would run by default.
Yes.
With cert expired when Apache restarted it hung at 100%.
With Apache @ 100% the cert renewal failed.
Upon restart Apache returned to 100%
Disabled Apache and rebooted.
With Apache disabled I was able to renew cert
With cert renewed upon restart Apache did not hang at 100%
All working.
root@mail:~# service apache2 stop
root@mail:~# service apache2 start
top shows apache running normally.
root@mail:~# certbot renew --dry-run
Processing /etc/letsencrypt/renewal/mail.mydomain.com.au.conf
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
tls-sni-01 challenge for mail.mydomain.com.au
Generating key (2048 bits): /etc/letsencrypt/keys/0005_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0005_csr-certbot.pem
/etc/letsencrypt/live/mail.mydomain.com.au/fullchain.pem (success)
Job for apache2.service failed. See ‘systemctl status apache2.service’ and ‘journalctl -xn’ for details.
top shows apache hung at 100%.
root@mail:~# reboot
Why are you stopping apache before running the renewal?
Generating key (2048 bits): /etc/letsencrypt/keys/0006_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0006_csr-certbot.pem
/etc/letsencrypt/live/mail.mydomain.com/fullchain.pem (success)
root@mail:~# reboot
