Apache first or certbot first?
My debian(8) host has an Apache2 web server that connects to a tomcat backend. At the moment it is configured for http only.
For security I want to exclusively use https and installed the certbot package to set up SSL first, then Apache2.
When I run
$ certbot --apache --domains rng-xnat.ecloud.vumc.nl
I get an error about the first challenge (tls-sni-01):
tls-sni-01 challenge for rng-xnat.ecloud.vumc.nl
Enabled Apache socache_shmcb module
Enabled Apache ssl module
/usr/lib/python2.7/dist-packages/OpenSSL/rand.py:58: UserWarning: implicit cast from ‘char *’ to a different pointer type: will be forbidden in the future (check that the types are as you expect; use an explicit ffi.cast() if they are correct)
result_code = _lib.RAND_bytes(result_buffer, num_bytes)
Waiting for verification…
Failed authorization procedure. rng-xnat.ecloud.vumc.nl (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout
    Domain: rng-xnat.ecloud.vumc.nl
    Type: connection
    Detail: Timeout
I have the ssh, http and https ports open in the firewall and I can open the site in my browser, so I’m not sure why certbot fails to connect to my host?
$ telnet rng-xnat.ecloud.vumc.nl 443
Trying 154.121.54.181...
^C
$ telnet rng-xnat.ecloud.vumc.nl 80
^C
From my point of view, I cannot connect to your host via http/https.
Thanks! I found the same on a website from outside my workplace’s domain. IP address works, hostname doesn’t. Will need to call the IT department for that. For the firewall options i have ports 22, 80, 443 and 8080 open.
From inside the domain I can do all those telnet options, EXCEPT port 443. It says: connection refused.
But as I said in my first post, I started setting up SSL because the Apache setup for HTTPS requires the SSL certificates to already be there? So this feels a bit like a catch-22: to get SSL I need Apache2 to already work for port 443, but to get it working I need the SSL certificate.
I get the feeling that I am missing something, probably something basic.
You don't need to setup SSL beforehand. Look at the webroot-plugin, which places the challenge files for http-01 authentication at a user-configurable place. Or use apache-plugin which automagically configures Apache during authorization and may even setup Apache for SSL after certificate issuance.
