My domain is: gul.ph
I ran this command: certbot --apache -d gul.ph -d www.gul.ph
The two names resolve to the same IP and there is no IPv6 involved.
So that is a good simple start.
If you can, please rerun the command with “–verbose” and show the extra output.
In the meantime I will see what I can from the Internets’ point of view.
tls-sni-01 uses port 443.
Only port 80 is connecting to that IP.
The “–apache” parameter requires port 443.
Also have a look at: Combining plugins
certbot run -a webroot -i apache -w /var/www/html -d example.com
As that may get you going and out of the “chicken and egg” problem with the “need 443, but don’t have 443” you seem to be in.
To enable 443, your site would need to be using TLS(SSL)
You may be able to use the snakeoil test certs generally loaded with Apache.
If this is your first time enabling TLS(SSL) on a site, we should just go about that in a more automated direction.
0.12.0 is not that old, not sure if it is the latest.
Can you try the Fedora-Apache recommended installation method?
It should just update the current certbot (if needed).
Or you could try “certbot-auto”:
mkdir /where/you/want/it/
cd /where/you/want/it/
wget https://dl.eff.org/certbot-auto
chmod a+x certbot-auto
sudo ./certbot-auto --apache -d gul.ph -d www.gul.ph
That’s not necessary for the tls-sni-01 challenge. It uses custom temporary certificates served through either an existing webserver (apache or nginx plugin) or a temporary Python server (standalone plugin) running on port 443.
This error is probably caused by a firewall issue.
Indeed, it’s something of a myth that you have to have an existing HTTPS site in order to use Certbot’s --apache or --nginx options. They’re quite willing to configure your server to listen on port 443 even if it didn’t previously do so. I agree with the suggestion of a firewall issue here.
What are the ways to know if I have firewall running on my server?
I have run systemctl status firewalld and I have seen active (running).
How can I enable my firewall to accept certbot challenge?
Thank you.
