Apache becomes unresponsive when running certbot
Since upgrading from ubuntu 18.10, apache became unresponsive every day, requiring a restart of the apache service to make it work again. Apache error log is then spammed with:
[Tue Nov 06 00:00:06.523969 2018] [core:error] [pid 17329] AH00546: no record of generation 0 of exiting child 24954
[Tue Nov 06 00:00:06.524015 2018] [core:notice] [pid 17329] AH00051: child pid 24955 exit signal Segmentation fault (11), possible coredump in /etc/apache2
I’ve narrowed the problem down to certbot, and I can reproduce it by running certbot --apache.
When running certbot, the apache logs will also contain the following entries:
[Tue Nov 06 08:25:04.991613 2018] [mpm_prefork:notice] [pid 25264] AH00171: Graceful restart requested, doing restart
AH00112: Warning: DocumentRoot [/var/lib/letsencrypt/tls_sni_01_page/] does not exist
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.0.1. Set the ‘ServerName’ directive globally to suppress this message
[Tue Nov 06 08:25:05.334889 2018] [ssl:warn] [pid 25264] AH01906: 9fb61462685251450e8beac7a5a4917d.27cc1ef6e6d55acaf1e478e0a46f6b1c.acme.invalid:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Tue Nov 06 08:25:05.335955 2018] [ssl:warn] [pid 25264] AH01906: 0a5476ddd68cfcf5a4061a1c6cb2fbc3.b080bc01f066e755ce11a4e2d87e045e.acme.invalid:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
bragi.timalkemade.nl
sudo certbot --apache
1: bragi.timalkemade.nl
blank to select all options shown (Enter ‘c’ to cancel):
tls-sni-01 challenge for bragi.timalkemade.nl
Waiting for verification…
Failed authorization procedure. bragi.timalkemade.nl (tls-sni-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout during connect (likely firewall problem)
    Domain: bragi.timalkemade.nl
    Type: connection
    Detail: Timeout during connect (likely firewall problem)
Apache/2.4.34 (Ubuntu)
Ubuntu 18.10
N/A
No
Hi @MakeTimeLad
you have a new Letsencrypt certificate, created today. So it works.
But:
The tls-sni-01 challenge is deprecated. Support ends 2019-02...
So next time switch to http - validation.
--preferred-challenges http
To make sure my site works again, I stopped apache and created a new one using the certbot certonly --standalone command. I’ll try to see if ‘–preferred-challenges http’ validation fixes the issue for --apache.
I just tried with --preferred-challenges http. Letsencrypt gave me a new certificate, but still made apache unresponsive afterwards.
After more investigation, the problem appears to be in apache itself. I haven’t found a solution yet, but for some reason the apachectl graceful command causes the issue. I’ll close this thread.
I fixed the problem, in case anyone else has the same issue. I was running with php 7.2 packages, but for some reason, the php7.0 module was enabled in apache. Uninstalling the php7.0 module and installing the the php7.2 module fixed the issue.
Thanks, good to know. If someone else has the same problem.
