My domain is: pepak.net
I ran this command: /usr/local/bin/certbot renew
as root
Processing /usr/local/etc/letsencrypt/renewal/pepak.net.conf
Unable to read ssl_module file; not disabling session tickets.
Renewing an existing certificate for forum.pepak.net and 5 more domains
Domain: forum.pepak.net
Type: connection
Detail: 185.216.75.212: Fetching http://forum.pepak.net/.well-known/acme-challenge/jp9rnsg4JR8Awlzr4I-MOUWhPS1bE7BzXLw_6rue3Ug: Connection refused
Domain: riva.pepak.net
Type: connection
Detail: 185.216.75.212: Fetching http://riva.pepak.net/.well-known/acme-challenge/iOuDW2O6w9eQQui-0lRoekWnIxaS9ay04KrILbULQX8: Connection refused
Domain: temp.pepak.net
Type: connection
Detail: 185.216.75.212: Fetching http://temp.pepak.net/.well-known/acme-challenge/68_yFfXaFCGM_SFrUEYR_nhKGBl9vW2C5fW-a2T1_R8: Connection refused
Domain: update.pepak.net
Type: connection
Detail: 185.216.75.212: Fetching http://update.pepak.net/.well-known/acme-challenge/sA8_9gHaNM-YcJmmx_B7gaMeFo1J0VA5gWU9vOcKLaM: Connection refused
Domain: www.pepak.net
Type: connection
Detail: 185.216.75.212: Fetching http://www.pepak.net/.well-known/acme-challenge/2Yn5Ugg0yBWhYoJeeClY5Ovi6W9zEU0CZZkfSU24aB8: Connection refused
Domain: ytd.pepak.net
Type: connection
Detail: 185.216.75.212: Fetching http://ytd.pepak.net/.well-known/acme-challenge/YFuF9dm-aMsVmMrksGW0VV1kNWm1VSXjJSifmwdyOcA: Connection refused
apache24 not running? (check /var/run/httpd.pid).
Unable to restart apache using ['apachectl', 'graceful']
Encountered exception during recovery: certbot.errors.MisconfigurationError: Error while running apachectl graceful.
Failed to renew certificate pepak.net with error: Some challenges have failed.
/usr/local/etc/letsencrypt/live/pepak.net/fullchain.pem (failure)
My web server is (include version): 2.4.56
The operating system my web server runs on is (include version): FreeBSD 13.2
My hosting provider, if applicable, is: Contabo
or certbot-auto --version
if you're using Certbot): 2.4.0
Looking through the log file, it seems that the problem is that after DEBUG:certbot.reverter:Creating backup of /usr/local/etc/apache24/extra/httpd-vhosts.conf
, Certbot fails to restart Apache (ERROR:certbot.util:Error while running apachectl graceful.
). Which would explain why the Let's Encrypt server is complaining that connection to my site are refused and why the webserver stops. What I don't understand is why would this change suddenly occur, the renewal had worked fine for at least a year or more until a short time ago. A manual apachectl graceful
works perfectly with no complaints from Apache, but the next time I try to renew the certificates, I get the same error. I expect certbot writes something into the configuration files that prevents Apache from restarting and then reverts the change so that my manual restarts work, but how can I fugure out what exactly it is? The certbot logfile doesn't seem to be telling me that:
2023-05-28 05:00:57,193:DEBUG:certbot_apache._internal.http_01:Adding a temporary challenge validation Include for name: None in: /usr/local/etc/apache24/extra/httpd-vhosts.conf
2023-05-28 05:00:57,193:DEBUG:certbot_apache._internal.http_01:writing a pre config file with text:
RewriteEngine on
RewriteRule ^/\.well-known/acme-challenge/([A-Za-z0-9-_=]+)$ /var/db/letsencrypt/http_challenges/$1 [END]
2023-05-28 05:00:57,194:DEBUG:certbot_apache._internal.http_01:writing a post config file with text:
<Directory /var/db/letsencrypt/http_challenges>
Require all granted
</Directory>
<Location /.well-known/acme-challenge>
Require all granted
</Location>
2023-05-28 05:00:57,225:DEBUG:certbot.reverter:Creating backup of /usr/local/etc/apache24/extra/httpd-vhosts.conf
2023-05-28 05:00:57,461:ERROR:certbot.util:Error while running apachectl graceful.
The apache error log doesn't seem to contain anything useful either:
[Sun May 28 05:12:51.957833 2023] [ssl:warn] [pid 77624] AH01909: pepak.net:443:0 server certificate does NOT include an ID which matches the server name
[Sun May 28 05:12:51.993588 2023] [ssl:warn] [pid 77625] AH01909: pepak.net:443:0 server certificate does NOT include an ID which matches the server name
[Sun May 28 05:12:52.122037 2023] [core:warn] [pid 77625] AH00098: pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun May 28 05:12:52.270672 2023] [mpm_prefork:notice] [pid 77625] AH00163: Apache/2.4.56 (FreeBSD) OpenSSL/1.1.1t-freebsd configured -- resuming normal operations
[Sun May 28 05:12:52.270807 2023] [core:notice] [pid 77625] AH00094: Command line: '/usr/local/sbin/httpd -D NOHTTPACCEPT'
[Sun May 28 05:13:00.225675 2023] [mpm_prefork:notice] [pid 77625] AH00171: Graceful restart requested, doing restart
[Sun May 28 05:13:00.267516 2023] [ssl:warn] [pid 77625] AH01909: pepak.net:443:0 server certificate does NOT include an ID which matches the server name
[Sun May 28 05:14:13.469579 2023] [ssl:warn] [pid 77749] AH01909: pepak.net:443:0 server certificate does NOT include an ID which matches the server name
[Sun May 28 05:14:13.509851 2023] [ssl:warn] [pid 77750] AH01909: pepak.net:443:0 server certificate does NOT include an ID which matches the server name
[Sun May 28 05:14:13.631389 2023] [core:warn] [pid 77750] AH00098: pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun May 28 05:14:13.720380 2023] [mpm_prefork:notice] [pid 77750] AH00163: Apache/2.4.56 (FreeBSD) OpenSSL/1.1.1t-freebsd configured -- resuming normal operations
[Sun May 28 05:14:13.720498 2023] [core:notice] [pid 77750] AH00094: Command line: '/usr/local/sbin/httpd -D NOHTTPACCEPT'
[Sun May 28 05:14:19.189581 2023] [mpm_prefork:notice] [pid 77750] AH00171: Graceful restart requested, doing restart
[Sun May 28 05:14:19.229678 2023] [ssl:warn] [pid 77750] AH01909: pepak.net:443:0 server certificate does NOT include an ID which matches the server name
[Sun May 28 05:16:02.025232 2023] [ssl:warn] [pid 77809] AH01909: pepak.net:443:0 server certificate does NOT include an ID which matches the server name
[Sun May 28 05:16:02.047596 2023] [ssl:warn] [pid 77810] AH01909: pepak.net:443:0 server certificate does NOT include an ID which matches the server name
[Sun May 28 05:16:02.119452 2023] [core:warn] [pid 77810] AH00098: pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun May 28 05:16:02.193223 2023] [mpm_prefork:notice] [pid 77810] AH00163: Apache/2.4.56 (FreeBSD) OpenSSL/1.1.1t-freebsd configured -- resuming normal operations
[Sun May 28 05:16:02.193392 2023] [core:notice] [pid 77810] AH00094: Command line: '/usr/local/sbin/httpd -D NOHTTPACCEPT'
[Sun May 28 05:16:21.357071 2023] [mpm_prefork:notice] [pid 77810] AH00171: Graceful restart requested, doing restart
[Sun May 28 05:16:21.400894 2023] [ssl:warn] [pid 77810] AH01909: pepak.net:443:0 server certificate does NOT include an ID which matches the server name
