Another "AttributeError: 'module' object has no attribute 'TLSSNI01'" help post
parcoursetdetours.ca
certbot renew --dry-run
An unexpected error occurred:
Please see the logfile '/tmp/tmp13xIsy/log' for more details.
That file has:
2020-12-17 15:59:43,276:DEBUG:certbot._internal.log:Exiting abnormally:
File "/usr/bin/certbot", line 9, in
load_entry_point('certbot==1.9.0', 'console_scripts', 'certbot')()
File "/usr/lib/python2.7/site-packages/certbot/main.py", line 15, in main
File "/usr/lib/python2.7/site-packages/certbot/_internal/main.py", line 1332, in main
plugins = plugins_disco.PluginsRegistry.find_all()
File "/usr/lib/python2.7/site-packages/certbot/_internal/plugins/disco.py", line 236, in find_all
plugin_ep = cls._load_entry_point(entry_point, plugins, with_prefix=False)
File "/usr/lib/python2.7/site-packages/certbot/_internal/plugins/disco.py", line 251, in _load_entry_point
plugin_ep = PluginEntryPoint(entry_point, with_prefix)
File "/usr/lib/python2.7/site-packages/certbot/_internal/plugins/disco.py", line 56, in init
self.plugin_cls = entry_point.load()
File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 2260, in load
entry = import(self.module_name, globals(),globals(), ['name'])
File "/usr/lib/python2.7/site-packages/certbot_apache/entrypoint.py", line 4, in
from certbot_apache import configurator
File "/usr/lib/python2.7/site-packages/certbot_apache/configurator.py", line 32, in
from certbot_apache import http_01
File "/usr/lib/python2.7/site-packages/certbot_apache/http_01.py", line 13, in
class ApacheHttp01(common.TLSSNI01):
File "/usr/lib/python2.7/site-packages/certbot/plugins/common.py", line 443, in getattr
return getattr(self._module, attr)
2020-12-17 15:59:43,276:ERROR:certbot._internal.log:An unexpected error occurred:
2020-12-17 15:59:43,276:ERROR:certbot._internal.log:AttributeError: 'module' object has no attribute 'TLSSNI01'
Server version: Apache/2.4.6 (Red Hat Enterprise Linux)
Server built: Apr 21 2020 10:19:09
Red Hat Enterprise Linux Server release 7.9 (Maipo)
N/A
Not sure. Old admin left, inherited this server.
Produce the same error as above
Did my research, ran
yum update certbot python2-certbot-apache
which told my both are up to date
package certbot-1.9.0-1.el7.noarch is already installed
package python2-certbot-apache-1.9.0-1.el7.noarch is already installed
Certificate has expired since Dec 10th. This server has been working fine for years. Not sure why it's complaining now :frowning:
This does not match what python2-certbot-apache-1.9.0-1.el7.noarch should be.
Perhaps:
yum reinstall python2-certbot-apache
If that doesn't work, what's the output of:
find /usr/lib/python2.7/site-packages/certbot_apache/ -type d
Thanks for the very quick reply :slight_smile:
That fixed it. This server has many vhosts and although it did renew that cert, it also gave me the following error while running certbot -q renew
Attempting to renew cert (coffres.ca) from /etc/letsencrypt/renewal/coffres.ca.conf produced an unexpected error: (104, 'Connection reset by peer'). Skipping.
Attempting to renew cert (dev.clicenligne.ca) from /etc/letsencrypt/renewal/dev.clicenligne.ca.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.',). Skipping.
Attempting to renew cert (fondationdelacite.ca) from /etc/letsencrypt/renewal/fondationdelacite.ca.conf produced an unexpected error: (104, 'Connection reset by peer'). Skipping.
Attempting to renew cert (lacitedesaffaires.com) from /etc/letsencrypt/renewal/lacitedesaffaires.com.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The following certs could not be renewed:
  /etc/letsencrypt/live/coffres.ca/fullchain.pem (failure)
  /etc/letsencrypt/live/dev.clicenligne.ca/fullchain.pem (failure)
  /etc/letsencrypt/live/fondationdelacite.ca/fullchain.pem (failure)
  /etc/letsencrypt/live/lacitedesaffaires.com/fullchain.pem (failure)
4 renew failure(s), 0 parse failure(s)
Some have been expired since last year! Oh well, I guess I have more digging to do...
Welcome to the Let's Encrypt Community, Sylvain :slightly_smiling_face:
You have certificates configured to use the manual authenticator, which requires either human intervention or "hook" scripts to setup/cleanup the challenges.
As for the "connection reset by peer" errors, they're most likely caused by webserver configuration issues. Maybe proxy related?
You might consider using
certbot certificates
and noting the names of unwanted certificates not in use then using
certbot delete --cert-name name
to get rid of those cruft certificates.
