Another 404 not found
Dear community,
this question has been asked before and answered successfully for most. however, not for me.
I have not found a similar case where curl works and letsencrypt does not.
My domain is: die-schenks.dyndns.org, nextcloud.die-schenks.dyndns.org, owncloud.die-schenks.dyndns.org
certbot certonly --webroot --webroot-path /var/www/html --agree-tos -w /etc/letsencrypt/ --expand -d die-schenks.dyndns.org,nextcloud.die-schenks.dyndns.org,owncloud.die-schenks.dyndns.org
It produced this output ( Ihad to garble http as the forum only allows 20 links?!)
http-01 challenge for die-schenks.dyndns.org
http-01 challenge for nextcloud.die-schenks.dyndns.org
http-01 challenge for owncloud.die-schenks.dyndns.org
Using the webroot path /etc/letsencrypt for all unmatched domains.
Waiting for verification…
Failed authorization procedure. owncloud.die-schenks.dyndns.org (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from ht tp://owncloud.die-schenks.dyndns.org/.well-known/acme-challenge/iffIkpt-q7l6wBwT4AoG0O7rO4zGsps1npNwWLfnMjI [89.244.123.125]: “\n\n404 Not Found\n\n
Not Found
\n<p”, die-schenks.dyndns.org (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from ht tp://die-schenks.dyndns.org/.well-known/acme-challenge/PrAEJREkBydte9wa1J9uo08KGMvpBmwksn2HXSDbelE [89.244.123.125]: “\n\n404 Not Found\n\n
Not Found
\n<p”, nextcloud.die-schenks.dyndns.org (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from ht tp://nextcloud.die-schenks.dyndns.org/.well-known/acme-challenge/9mYSfDEOX-aR9vECW4kRg26KZmX8I9XG4UzZssxxErU [89.244.123.125]: “\n\n404 Not Found\n\n
Not Found
\n<p”
    Domain: owncloud.die-schenks.dyndns.org
    Detail: Invalid response from
    Found\n\n
    Not Found
    \n<p”
    Domain: die-schenks.dyndns.org
    Found\n\n
    Not Found
    \n<p”
    Domain: nextcloud.die-schenks.dyndns.org
    Found\n\n
    Not Found
    \n<p”
Apache 2.4.38 ubuntu
NAME=“Ubuntu”
VERSION=“19.04 (Disco Dingo)”
0.31.0
if I test with curl it works:
curl -ikL4 ht tp://nextcloud.die-schenks.dyndns.org/.well-known/acme-challenge/nag
HTTP/1.1 200 OK
Date: Wed, 21 Aug 2019 21:09:15 GMT
Server: Apache/2.4.38 (Ubuntu)
Last-Modified: Wed, 21 Aug 2019 20:45:21 GMT
ETag: “b-590a6a6d1715b”
Accept-Ranges: bytes
Content-Length: 11
HalloHallo
I cannot find a hint what is going wrong. I read about an issue with ipv6 (which I dont have on my lan). I am using dyndns for name resolving and removed the ipv6 entry.
It looks like the request uses ipv4 as one can the in the response of letsencrypt.
The server is in the lan behind a fritz box router, which forwards the ports 443 and 80. The web server config is stripped down just to get letsencrypt on port 80 running. usually it is a reverse proxy on 443.
apache config:
<VirtualHost *:80>
ServerName die-schenks.dyndns.org
ServerAlias nextcloud.die-schenks.dyndns.org
ServerAlias owncloud.die-schenks.dyndns.org
    DocumentRoot /var/www/html
I run all command as root.
Thanks for your help
Hi @cryptorius
your command looks wrong. --webroot-path and -w are the same, -w is the shortcut.
So the perhaps wrong -w option is used.
Read
https://certbot.eff.org/docs/using.html
  --webroot-path WEBROOT_PATH, -w WEBROOT_PATH
                        public_html / webroot path. This can be specified
                        multiple times to handle different domains; each
                        domain will have the webroot path that preceded it.
                        For instance: `-w /var/www/example -d example.com -d
                        www.example.com -w /var/www/thing -d thing.net -d
                        m.thing.net` (default: Ask)
Checked your file https://check-your-website.server-daten.de/?q=nextcloud.die-schenks.dyndns.org%2F.well-known%2Facme-challenge%2Fnag that looks good:
http://nextcloud.die-schenks.dyndns.org/.well-known/acme-challenge/nag
89.244.123.125 200 0.023 H
http://www.nextcloud.die-schenks.dyndns.org/.well-known/acme-challenge/nag
The expected result http status 200. Your https is wrong, port 443 sends http content. But now that's not a problem.
So remove the -w option and the value and use your correct webroot.
