An unexpected error occurred: SysCallError: (104, 'Connection reset by peer')
groupeguerin.ca
I ran this command: certbot --apache certonly --domain groupeguerin.ca
aving debug log to /var/log/letsencrypt/letsencrypt.log
SysCallError: (104, ‘Connection reset by peer’)
My web server is (include version): apache 2.4.6
The operating system my web server runs on is (include version):CentOS Linux release 7.8.2003 (Core)
no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):certbot 1.6.0
Could you please share the log file?
I agree with @Osiris that it could be helpful to see the logs, but this error also suggests a likelihood that your server's network doesn't allow outbound HTTPS connections—do you think the server could be behind a firewall of some kind that restricts its ability to connect elsewhere on the Internet?
