via cpanel, click to “autossl”
it either green locked the main domain and some others like panel.domain, or if I remove that cert and ask it to autossl the “origin.camsyrup” - it seems to work to make a cert for that alias, but then it does not green lock the main domain…
specs: CENTOS 6.10 | virtuozzo | v74.0.8
whm / vps hosting / running through cloudflare though, and added an addon of nginx
yes can root login
cpanel 74.0.8 (also whm… virtuozzo | v74.0.8 )
Am thinking that maybe I need to do a wildcard cert in order to secure origin.domain
(which is a domain alias, not setup as subdomain in this situation, as it needs to pull from the main domain (public_html) folder for a CDN to pull from)
I posted some other details here: https://forums.cpanel.net/threads/autossl-with-domain-alias-and-wildcard.638341/ a couple days ago, but I get the feeling that the autossl plugin currently available with cpanel is not ready to handle wildcard stuff,
and now that I re-read the docs that I linked to in that post, I see that the plugin which had those docs is a premium plugin costing extra money, so perhaps the info there is not pertinent / this is not possible with the current setup (?)
so maybe I need to do this via command line? Or perhaps others have a similar situation i which there is a better solution?
