After running certbot the connection is over IPv4 instead of IPv6
Hello,
After running certbot --nginx the connection is established via IPv4 instead of IPv6 in Chrome. The server is running with a fresh Ubuntu 18.04.01 installation and Nginx 1.14.0. HTTPS is activated without problems.
Here is the Nginx configuration before running certbot:
    listen 80;
    listen [::]:80;
    server_name example.com www.example.com;
    if ($host = example.com) {
        return 301 https://www.$host$request_uri;
    root /var/www/example.com/public;
    add_header X-Frame-Options "SAMEORIGIN";
    add_header X-XSS-Protection "1; mode=block";
    add_header X-Content-Type-Options "nosniff";
    index index.html index.htm index.php;
    charset utf-8;
    access_log /var/log/nginx/example.com.log;
    error_log /var/log/nginx/example.com-error.log error;
        try_files $uri $uri/ /index.php?$query_string;
    location = /favicon.ico { access_log off; log_not_found off; }
    location = /robots.txt  { access_log off; log_not_found off; }
    error_page 404 /index.php;
    location ~ \.php$ {
        fastcgi_split_path_info ^(.+\.php)(/.+)$;
        include snippets/fastcgi-php.conf;
        fastcgi_pass unix:/run/php/php7.2-fpm.sock;
        include fastcgi_params;
    location ~ /\.(?!well-known).* {
        deny all;
1: example.com
2: www.example.com
: 1 2
1: No redirect
2: Redirect
: 2
After running certbot:
    charset utf-8;
    location ~ \.php$ {
        deny all;
    ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem; # managed by Certbot
    if ($host = www.example.com) {
    } # managed by Certbot
    listen 80;
    listen [::]:80;
Thanks for your help!
What’s the domain?
Those two server blocks don’t look like they’d fail over IPv6. There could be an issue in another server block, or with something external to Nginx like a firewall.
The firewall is now disabled but it still does not work. The domain is www.jobion.de
Hi @heiner
I don't see an ipv6 - address.
D:\temp>nslookup www.jobion.de.
Address: 159.69.152.93
http://jobion.de/ and https://jobion.de/ work for me on IPv6.
However, https://jobion.de/ redirects to https://www.jobion.de/, which doesn’t have an AAAA record in the DNS.
jobion.de.      3600  A     159.69.152.93
jobion.de.      3600  AAAA  2a01:4f8:1c0c:4caf::1
www.jobion.de.  3600  A     159.69.152.93
True, non-www works with IPv6. I will add AAAA record for www in the DNS.
Thank you very much!
