My domain is: multiple domains
certbot -v certonly -d *.domain2.ext -d *.domain3.ext -d *.domain1.ext --server https://acme-v02.api.letsencrypt.org/directory --dns-cloudflare --dns-cloudflare-credentials /root/.secrets/certbot/cloudflare.ini --preferred-challenges dns-01
Plugins selected: Authenticator dns-cloudflare, Installer None
(ref: /etc/letsencrypt/renewal/domain2.ext-0001.conf)
What would you like to do?
1: Keep the existing certificate for now
2: Renew & replace the certificate (may be subject to CA rate limits)
Renewing an existing certificate for *.domain2.ext and 2 more domains
Certificate is saved at: /etc/letsencrypt/live/domain2.ext-0001/fullchain.pem
Key is saved at: /etc/letsencrypt/live/domain2.ext-0001/privkey.pem
This certificate expires on 2022-05-01.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
- Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
- Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
But I have an issue with adding more domains to the certificate. I created a new DNS-api key for 6 domains and updated this in /root/.secrets/certbot/cloudflare.ini
When trying to add more domains via
certbot -v certonly -d *.domain1.ext -d *.domain2.ext -d *domain3.ext -d *.domain4.ext -d *.domain5.ext -d *.domain6.ext --server https://acme-v02.api.letsencrypt.org/directory --dns-cloudflare --dns-cloudflare-credentials /root/.secrets/certbot/cloudflare.ini --preferred-challenges dns-01
Results in
requested (ref: /etc/letsencrypt/renewal/domain2.ext-0001.conf)
It contains these names: *.domain1.ext, *.domain2.ext,
*.domain3.ext
You requested these names for the new certificate: *.domain1.ext,
*.domain2.ext, *.domain3.ext, *.domain4.ext, *.domain5.ext,
*.domain6.ext.
certificate?
(E)xpand/(C)ancel: e
Renewing an existing certificate for *.domain1.ext and 5 more domains
dns-01 challenge for domain4.ext
dns-01 challenge for domain5.ext
dns-01 challenge for domain6.ext
Error determining zone_id: 6003 Invalid request headers. Please confirm that you have supplied valid Cloudflare API credentials.
Letsencrypt.log (error part)
2022-01-31 19:56:18,812:DEBUG:acme.client:Storing nonce: 0002CDwPhlqWH4xhIUzWkacG9-8SgkHwT9MxjXrP6OAxPao
2022-01-31 19:56:18,813:INFO:certbot._internal.auth_handler:Performing the following challenges:
2022-01-31 19:56:18,813:INFO:certbot._internal.auth_handler:dns-01 challenge for domain4.ext
2022-01-31 19:56:18,814:INFO:certbot._internal.auth_handler:dns-01 challenge for domain5.ext
2022-01-31 19:56:18,815:INFO:certbot._internal.auth_handler:dns-01 challenge for domain6.ext
2022-01-31 19:56:18,826:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.cloudflare.com:443
2022-01-31 19:56:19,789:DEBUG:urllib3.connectionpool:https://api.cloudflare.com:443 "GET /client/v4/zones?name=domain4.ext&per_page=1 HTTP/1.1" 400 None
2022-01-31 19:56:19,794:DEBUG:certbot._internal.error_handler:Encountered exception:
File "/usr/local/lib/python3.6/site-packages/certbot_dns_cloudflare/_internal/dns_cloudflare.py", line 183, in _find_zone_id
zones = self.cf.zones.get(params=params) # zones | pylint: disable=no-member
File "/usr/local/lib/python3.6/site-packages/CloudFlare/cloudflare.py", line 674, in get
params, data)
File "/usr/local/lib/python3.6/site-packages/CloudFlare/cloudflare.py", line 128, in call_with_auth
params, data, files)
File "/usr/local/lib/python3.6/site-packages/CloudFlare/cloudflare.py", line 498, in _call
raise CloudFlareAPIError(code, message, error_chain)
CloudFlare.exceptions.CloudFlareAPIError: Invalid request headers
File "/usr/lib/python3.6/site-packages/certbot/_internal/auth_handler.py", line 85, in handle_authorizations
resps = self.auth.perform(achalls)
File "/usr/lib/python3.6/site-packages/certbot/plugins/dns_common.py", line 76, in perform
self._perform(domain, validation_domain_name, validation)
File "/usr/local/lib/python3.6/site-packages/certbot_dns_cloudflare/_internal/dns_cloudflare.py", line 74, in _perform
self._get_cloudflare_client().add_txt_record(domain, validation_name, validation, self.ttl)
File "/usr/local/lib/python3.6/site-packages/certbot_dns_cloudflare/_internal/dns_cloudflare.py", line 106, in add_txt_record
zone_id = self._find_zone_id(domain)
File "/usr/local/lib/python3.6/site-packages/certbot_dns_cloudflare/_internal/dns_cloudflare.py", line 202, in _find_zone_id
.format(code, msg, hint))
certbot.errors.PluginError: Error determining zone_id: 6003 Invalid request headers. Please confirm that you have supplied valid Cloudflare API credentials. (Did you copy your entire API token/key? To use Cloudflare tokens, you'll need the python package cloudflare>=2.3.1. This certbot is running cloudflare 2.8.15)
My problem: I can renew the 3 initial domains, but I run into a problem when adding 3 extra. No clue why, because I updated the DNS-API key (did throw away the initial key) so it includes the 6 domains.
I'm doing something wrong but I don't know what
My web server is (include version): Running Iredmail (latest)
The operating system my web server runs on is (include version): Centos 8
My hosting provider, if applicable, is: Cloudflare
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.22.0
