That didn't resolve like that before. I think they took my advice and since added a CNAME for that www.sandbox subdomain.
Because unboundtest.com also resolves the CAA query properly now too - no SERVFAIL
I added a sandbox2.rpiweather.net to my server but did not add a CNAME. I can reach that site, so it seems the CNAME isn't needed as you pointed out.
My question now is this: Should I (1) delete the *.rpiweather.net records and keep CNAMES that point to rpiweather.net, or (2) delete all the CNAMES and let the wild card records redirect all subdomains to rpiweather.net?
I would do (2).
I would too but I would also remove your DNSSEC
I suggested the CNAME for your www.sandbox.rpiweather.net domain as a work-around since it was getting SERVFAIL from Let's Encrypt server and unboundtest.com
So, just removing the CNAMEs will probably bring that error back.
I removed the CNAME DNS records but I kept the DNSSEC enabled because it is required for some webhook POST requests that originate on a server in the Netherlands (some EU rule?).
But, once I did that I get a clean certbot dry run result:
pi@HomeAutomation:~ $ sudo certbot certonly --dry-run --webroot -w /var/www/sandbox.rpiweather.net -d sandbox.rpiweather.net,www.sandbox.rpiweather.net
Simulating a certificate request for sandbox.rpiweather.net and www.sandbox.rpiweather.net
http-01 challenge for sandbox.rpiweather.net
http-01 challenge for www.sandbox.rpiweather.net
Using the webroot path /var/www/sandbox.rpiweather.net for all unmatched domains.
- The dry run was successful.
I also ran the unboundtest.com on sandbox.rpiweather.net and didn't see any "SERVFAIL" errors:
unbound-2024-04-19.txt (626.4 KB)
Having made these changes am I OK to proceed with obtaining a cert for the sandbox.rpiweather.net subdomain? If yes, which command should I run? (I don't want to be experimenting lest I mangle things up again).
^^ same command - just without the "--dry-run"
Then show:
certbot certificates
I got this:
pi@HomeAutomation:~ $ sudo certbot certonly --webroot -w /etc/nginx -d sandbox.rpiweather.net,www.sandbox.rpiweather.net
Requesting a certificate for sandbox.rpiweather.net and www.sandbox.rpiweather.net
Using the webroot path /etc/nginx for all unmatched domains.
Challenge failed for domain www.sandbox.rpiweather.net
Domain: www.sandbox.rpiweather.net
Detail: 2600:4040:5050:ce00:d6c2:fe84:f82f:13a7: Invalid response
from
http://www.sandbox.rpiweather.net/.well-known/acme-challenge/EXv9-Fu7CddEDfc3-DjDBUY9szqd7HIQmOImS3ydNZM:
404
pi@HomeAutomation:~ $ sudo certbot certificates
Found the following certs:
Certificate Name: rpiweather.net
Serial Number: 349d764bbce954fcc7e2aa5ee51e3d9291a
Key Type: RSA
Domains: rpiweather.net www.rpiweather.net
Expiry Date: 2024-06-22 20:08:59+00:00 (VALID: 63 days)
Certificate Path: /etc/letsencrypt/live/rpiweather.net/fullchain.pem
Private Key Path: /etc/letsencrypt/live/rpiweather.net/privkey.pem
And when I drop the www.sandbox.rpiweather.net I got this:
/etc/letsencrypt/live/sandbox.rpiweather.net/fullchain.pem
/etc/letsencrypt/live/sandbox.rpiweather.net/privkey.pem
Your certificate will expire on 2024-07-19. To obtain a new or
tweaked version of this certificate in the future, simply run
certbot again. To non-interactively renew *all* of your
certificates, run "certbot renew"
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
Key Type: RSA
Certificate Name: sandbox.rpiweather.net
Serial Number: 37aff6da84c82b45a037a4cf5415ed45bb0
Key Type: RSA
Domains: sandbox.rpiweather.net
Expiry Date: 2024-07-19 02:02:33+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/sandbox.rpiweather.net/fullchain.pem
Private Key Path: /etc/letsencrypt/live/sandbox.rpiweather.net/privkey.pem
And oddly enough sandbox.rpiweather.net works and www.sandbox.rpiweather.net works as well.
This is my nginx config file for sandbox.rpiweather.net:
# sudo certbot certonly --dry-run --webroot -w /etc/nginx -d sandbox.rpiweather.net,www.sandbox.rpiweather.net
listen 80;
listen [::]:80;
server_name sandbox.rpiweather.net www.sandbox.rpiweather.net;
# ACME Challenges use this root folder (from your old https server block)
root /var/www/sandbox.rpiweather.net;
# All other requests get redirected to https
listen 443 ssl;
listen [::]:443 ssl;
index index.html;
# RSA certificate
ssl_certificate /etc/letsencrypt/live/sandbox.rpiweather.net/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/sandbox.rpiweather.net/privkey.pem; # managed by Certbot
#include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
try_files $uri $uri/ =404;
Does this mean all is well and I should just drop the www.sandbox.rpiweather.net from the certbot command? Any issues with renewals?
Since @Bruce5051 didn't see that, I think you might be having a browser adaptation where the browser automatically accepts a certificate mismatch based on removing the www automatically. I think Chrome does this and Firefox doesn't.
This is bad practice:
It is the same path as the root directory of the HTTPS vhost.
You used the wrong -w folder path in above command again.
Below was the one that worked earlier.
But of course omit --dry-run to get a production cert now
Ah ha, that was the problem!
I reran using the correct root folder and got this:
pi@HomeAutomation:~ $ sudo certbot certonly --webroot -w /var/www/sandbox.rpiweather.net -d sandbox.rpiweather.net
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/sandbox.rpiweather.net.conf)
What would you like to do?
1: Keep the existing certificate for now
2: Renew & replace the certificate (may be subject to CA rate limits)
Renewing an existing certificate for sandbox.rpiweather.net
pi@HomeAutomation:~ $ sudo certbot certonly --webroot -w /var/www/sandbox.rpiweather.net -d sandbox.rpiweather.net,www.sandbox.rpiweather.net
requested (ref: /etc/letsencrypt/renewal/sandbox.rpiweather.net.conf)
It contains these names: sandbox.rpiweather.net
You requested these names for the new certificate: sandbox.rpiweather.net,
www.sandbox.rpiweather.net.
Did I do that right?
I get this:
pi@HomeAutomation:~ $ sudo nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
types_hash_max_size 2048;
# server_tokens off;
server_names_hash_bucket_size 64;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
# configuration file /etc/nginx/modules-enabled/70-mod-stream-geoip.conf:
load_module modules/ngx_stream_geoip_module.so;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
listen 80 default_server;
# SSL configuration
root /var/www/html;
server_name _;
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
# fastcgi_pass unix:/run/php/php7.4-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
#server {
# listen 80;
# listen [::]:80;
# server_name example.com;
# root /var/www/example.com;
# index index.html;
# location / {
# try_files $uri $uri/ =404;
# configuration file /etc/nginx/sites-enabled/rpiweather.net:
listen 80;
listen [::]:80;
server_name rpiweather.net www.rpiweather.net;
root /var/www/rpiweather.net;
listen 443 ssl;
index index.html;
# RSA certificate
ssl_certificate /etc/letsencrypt/live/rpiweather.net/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/rpiweather.net/privkey.pem; # managed by Certbot
# configuration file /etc/nginx/sites-enabled/sandbox.rpiweather.net:
listen 80;
listen [::]:80;
listen 443 ssl;
index index.html;
# RSA certificate
# configuration file /etc/nginx/sites-enabled/sandbox2.rpiweather.net:
listen 80;
listen [::]:80;
server_name sandbox2.rpiweather.net www.sandbox2.rpiweather.net;
root /var/www/sandbox2.rpiweather.net;
listen 443 ssl;
index index.html;
# RSA certificate
#ssl_certificate /etc/letsencrypt/live/sandbox.rpiweather.net/fullchain.pem; # managed by Certbot
#ssl_certificate_key /etc/letsencrypt/live/sandbox.rpiweather.net/privkey.pem; # managed by Certbot
The only thing I would change is this folder misuse/overlap:
The challenge folder should be ONLY for the challenge files.
Set those to some unique folder.
[they can all use the same folder]
I made a /var/www/ACMEchallenge folder and set the root accordingly in all 3 config files.
I now get this response to the certbot dry-run command:
pi@HomeAutomation:/var/www/ACMEchallenge $ sudo certbot certonly --dry-run --webroot -w /var/www/sandbox.rpiweather.net -d sandbox.rpiweather.net,www.sandbox.rpiweather.net
Simulating renewal of an existing certificate for sandbox.rpiweather.net and www.sandbox.rpiweather.net
Challenge failed for domain sandbox.rpiweather.net
Domain: sandbox.rpiweather.net
from
http://sandbox.rpiweather.net/.well-known/acme-challenge/H0QvQLOquFEccCsrPSGsPFYmW8aHmHCh4F1C1ZS3LEg:
404
from
http://www.sandbox.rpiweather.net/.well-known/acme-challenge/WeJ5CIohn7QDlDpx0JLGnFk2I4hyncxsL78krvaf6pg:
404
This is the nginx -T response:
pi@HomeAutomation:/var/www/ACMEchallenge $ sudo nginx -T
user www-data;
pid /run/nginx.pid;
events {
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
# SSL Settings
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
#mail {
# server {
# protocol pop3;
# proxy on;
# server {
# protocol imap;
# proxy on;
types {
text/css css;
text/xml xml;
image/gif gif;
text/mathml mml;
text/plain txt;
image/png png;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/webp webp;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
video/mp2t ts;
video/mp4 mp4;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-wmv wmv;
# SSL configuration
root /var/www/html;
server_name _;
#location ~ /\.ht {
# deny all;
#server {
# listen 80;
# listen [::]:80;
# index index.html;
# location / {
listen 80;
listen [::]:80;
root /var/www/ACMEchallenge;
listen 443 ssl;
index index.html;
# RSA certificate
listen 80;
listen [::]:80;
listen 443 ssl;
index index.html;
# RSA certificate
listen 80;
listen [::]:80;
listen 443 ssl;
index index.html;
# RSA certificate
And the folder details:
pi@HomeAutomation:/var/www/ACMEchallenge $ ls -l /var/www
total 24
drwxr-xr-x 2 root root 4096 Apr 20 07:07 ACMEchallenge
drwxr-xr-x 2 root root 4096 Apr 14 12:45 GPStracker.rpiweather.net
drwxr-xr-x 6 www-data pi 4096 Mar 23 07:11 html
drwxr-xr-x 5 pi pi 4096 Apr 13 07:46 rpiweather.net
drwxr-xr-x 2 root root 4096 Apr 19 17:41 sandbox2.rpiweather.net
drwxr-xr-x 2 root root 4096 Apr 20 07:13 sandbox.rpiweather.net
It is a bit off topic here, but as you are using dynu.com you may want to play with my dynDNS update program: https://github.com/bruncsak/dynu.sh. At least listing the content of your zone: dynu.sh getdns. It is possible to use for DNS-01 challenges to get certificate (even wildcard one), but I never tried to interface to the certbot ACME client.
First, let me say I do not agree with @rg305 that using a different folder is better practice or gives you better security. I think it was fine before. I think you could just change the acme challenge root folder in nginx back to how it was before and continue as you were.
But, if you leave the acme challenge folder as /var/www/ACMEchallenge your command should be:
sudo certbot certonly --dry-run --webroot -w /var/www/ACMEchallenge -d sandbox.rpiweather.net,www.sandbox.rpiweather.net
You will have to repeat the command for each of your certs. Note the --dry-run just tests the command. Once it works you need to issue it again without --dry-run
If I use the --nginx option rather than the --webroot, does the certbot alter the config files when you first run the command to setup the ACME folder? If so, how does it decide on the folder name?
Is there any downside to using the same root folder for the challenge folder across multiple subdomains?
Not sure if this is of concern...
But the Location statement ends with a slash and the root statement does not.
I think they should agree.
Either:
I'd use a slash on both.
