Activate SSL on port 33443 instead of 443
My domain is:http://hepiacloudlab.eig.ch:33443
I ran this command:certbot --apache
It produced this output: Failed to connect to 129.194.185.22:443 for tls-sni-01 challenge
My operating system is (include version):ubuntu 16.04
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):yes
@amirdhaoui
the ACME specification defines the TLS-SNI challenge will only work on port 443 so you need to ensure your environment conforms to this
Andrei
@ahaw021
is there an other solution instead of TLS-SNI ?
Yes, there’s the HTTP-01 challenge, which requires a connection on port 80, and the DNS-01 challenge, which requires making modifications to your DNS records.
