My domain is: e-sol.org.uk
I ran this command:Complete-ACMEChallenge autodiscover.e-sol.org.uk -ChallengeType http-01 -Handler iis -HandlerParameters @{ WebSiteRef = ‘Default Web Site’ } | select Identifier, status, Expires
Complete-ACMEChallenge : The given key was not present in the dictionary.
At line:1 char:1
My operating system is (include version): 2008 R2
My web server is (include version): IIS 7.5
ahaw021
2
hi @rf_at_e-sol
have a look at the docs https://github.com/ebekker/ACMESharp/wiki/Example-Usage
acmesharp works on a concept of a vault which contains keys, certs and csrs
A) have you initialised the vault
B) have you generated an RSA Key (to authenticate against letsencrypt)
C) have you generate a web RSA key and CSR
Andrei
Thanks for the reply. I’ve followed the doc you linked to.
When I get to the command:
Get-ACMEChallengeHandlerProfile -ListChallengeHandlers
I only get manual, which is obviously why the iis handler request fails
Any idea how I install ACMESharp.Providers.IIS (and where I get the files from for it) so that iis is listed as an available handler?
ahaw021
4
hi @rf_at_e-sol
should be part of the bundle
how did you build this?
I downloaded it from here - http://www.netometer.com/downloads/ACME-Exchange.zip
I’ve also tried downloading and installing this https://github.com/ebekker/ACMESharp/releases/download/v0.8.1.0-EA/ACME-posh.zip
And I’ve tried install-package ACMESharp
but still the only handler available is manual
Any help is greatly appreciated.
Thanks
Rob
BUMP…
Anyone have an idea how I can add other handlers?
system
Closed
7
