ACME v2 - Order processing for a long time
I recently ordered for a certificate from acmev2 staging endpoint and have successfully validated all authorizations. The order status changed to processing once I submitted CSR to the ‘finalize’ endpoint. However the status has ever since been ‘processing’ and am still wondering why it is taking so much time.
Order URL : https://acme-staging-v02.api.letsencrypt.org/acme/order/5356046/1725
Is there anything i’m missing ?
Thanks,
Sanjaykumar M
I think you've uncovered a bug in order processing. I'll investigate and respond further.
Do you have any update on this issue ?
The order status is still in ‘processing’ state.
Thanks
Any update on this issue ?
Hi @m.sanjay94,
My apologies - I lost track of this thread and didn’t reply with updates.
The bug you encountered is being tracked in the Boulder repository as Issue 3403. I have a fix in a pull request but it is presently held up by a separate fix that has been slower than expected going through reviews.
The short answer is the problem is known & understood, there’s a fix in the works, and I’d expect it to be fixed in the staging environment in a week or so.
Thanks for your patience!
