Id like to add another subdomain running on the same IP address but different physical host however in trying ./acme.sh/acme.sh --issue --staging --log -d mysub.domain.com -d myothersub.domain.com --standalone --httpport 8081
I get no idea if its tested correctly, changing back to the existing script not including the other subdomain again i get red writting crying of version changes, my cert is due for renewal in 7 days and im not sure how i can get difinitive answer on whether it will pass, im using the --staging command to test adding another subdomain. Im reading acme.sh supports v1 and v2 so why the red writting.
mysub.domain.com
./acme.sh/acme.sh --issue --staging --log -d mysub.domain.com -d --standalone --httpport 8081
[Fri 1 May 2020 15:50:16 AEST] Using stage ACME_DIRECTORY: https://acme-staging.api.letsencrypt.org/directory
[Fri 1 May 2020 15:50:18 AEST] Standalone mode.
[Fri 1 May 2020 15:50:18 AEST] Registering account
[Fri 1 May 2020 15:50:20 AEST] Register account Error: {“type”:“urn:acme:error:unauthorized”,“detail”:“Account creation on ACMEv1 is disabled. Please upgrade your ACME client to a version that supports ACMEv2 / RFC 8555. See End of Life Plan for ACMEv1 for details.”,“status”: 403}
[Fri 1 May 2020 15:50:20 AEST] Please check log file for more details: /Users/macmedic/.acme.sh/acme.sh.log
apache
osx 10.11.6
vps
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 2.8.0
