Multi
havnt ran any command yet
not listed
NA
DEBIAN
CLOUDFLARE
YES
NO
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): acme.sh version 3.0.1
We have several domains using a singular domain to send email some have their own MX record some use the main hosts record.
example : mastermx.examplehost.com (the main servers MX record and DNS hosted with cloudflare)
other domains that use the mailhost to send and receive emails such as hostedemail.othercompany.com completely.differentdomain.com nothingtodo.withmastermx.com
What im finding is the certificate is listing all domain names as alternatives -
Using mastermx.examplehost.com as the MX record for completely.differentdomain.com (adding mastermx.examplehost.com as the MX in cloudflare for the completely.differentdomain.com DNS) some programs like outlook do not like this and complain "Target principal name is incorrect" on the SSL verification and fails.
Is there a way to use acme.sh to renew say mastermx.example.com without showing alternative DNS names in the certificate ? If only for privacy I think this is the incorrect way to do it?
If all domains DNS are hosted with cloudflare is there a simpler way to do this under one domain name than 6 standalone dns alias's that show up on the cert....sorry if this is rambling above its a bit greek to me !
