The Let's Encrypt API server gives you this error message:
When trying to connect to mail.fabioferrero.it, which LE resolved to 217.61.59.235. TLS-ALPN-01 challenges are always validated on port 443.
I see that you're using a different port in acme.sh (4242). This is fine, as long as you have some forwarding in place that forwards port 443 to your internal port (4242). Please double check that you have such a forwarding in place, or configure acme.sh to listen on port 443.
The acme.sh documentation can be rather poor, yeah.
This is mostly a legal thing. RFC 8737 states for the TLS-ALPN-01 challenge:
The ACME server initiates a TLS connection to the chosen IP address. This connection MUST use TCP port 443.
Similar statement exist in RFC 8555 for the HTTP-01 challenge (must use port 80).
Back when ACME was standarized, there were discussions whether to allow other ports to 80 and 443. These suggestions did not make it into the standards/requirements however. Unless the rules are changed, Let's Encrypt can't do anything.
The only way to not use port 80 or 443 is to use the DNS-01 challenge.
In addition to the above: these restrictions aren't thought up by Let's Encrypt nor by the RFCs themselves, but are mandated by the CA/Browser Forum Baseline Requirements.
