Hello,
I'm unable to resolve this issue. I've managed to set up a web server httpd, but now I can't enable https with acme-client. Maybe something wrong with ports because I haven't done anything with firewall yet.
I have A- and AAAA-records.
akapinos.space
acme-client -v akapinos.space
acme-client: https://acme-v02.api.letsencrypt.org/directory: directories
acme-client: acme-v02.api.letsencrypt.org: DNS: 172.65.32.248
acme-client: dochngreq: https://acme-v02.api.letsencrypt.org/acme/authz-v3/14314792266
acme-client: challenge, token: lBPkIEn7LFmpmoRm6RJGhkzFyyaMO6NGeZdKWkWYQdo, uri: https://acme-v02.api.letsencrypt.org/acme/chall-v3/14314792266/KEe0qg, status: 2
acme-client: dochngreq: https://acme-v02.api.letsencrypt.org/acme/authz-v3/14326961502
acme-client: challenge, token: BPM6Dv6_U5_d4Fh1ZtDdJLUzo6I6DC6tpYMioP24X-o, uri: https://acme-v02.api.letsencrypt.org/acme/chall-v3/14326961502/rV_hSw, status: 0
acme-client: /var/www/acme/BPM6Dv6_U5_d4Fh1ZtDdJLUzo6I6DC6tpYMioP24X-o: created
acme-client: https://acme-v02.api.letsencrypt.org/acme/chall-v3/14326961502/rV_hSw: challenge
acme-client: order.status 0
acme-client: challenge, token: BPM6Dv6_U5_d4Fh1ZtDdJLUzo6I6DC6tpYMioP24X-o, uri: https://acme-v02.api.letsencrypt.org/acme/chall-v3/14326961502/rV_hSw, status: -1
acme-client: order.status -1
acme-client: Fetching http://www.akapinos.space/.well-known/acme-challenge/BPM6Dv6_U5_d4Fh1ZtDdJLUzo6I6DC6tpYMioP24X-o: Timeout during connect (likely firewall problem)
acme-client: bad exit: netproc(93325): 1
httpd.
OpenBSD 6.8
NameCheap.
Yes.
No.
I use acme-client.
You have an IPv6 address configured for your website (2a07:8dc1:20:0:c3:7eff:fe1c:85a8) which is not responding.
While your IPv4 address seems to work nicely, Let's Encrypt prefers IPv6, so if you have a non-functional IPv6 address, it won't work.
So there is the problem with IPv6. How to fix this?
When I configured my VPS I chose "Custom ISO". Maybe I missed something during the installation or didn't configure IPv6 after? I took these IP addresses from VPS Dashboard.
I've also tried using auto-configurated FreeBSD. I've managed to setup obhttpd, but struggling the same issue with https using acme.sh.
The output: akapinos.space:Verify error:Fetching http://www.akapinos.space/.well-known/acme-challenge/-Ry7qMfJa5X24GnGdIZKis9pYQmCZOzfixb8eBj1irc: Timeout during connect (likely firewall problem)
Start by removing the AAAA entry from DNS.
Then get IPv6 working.
Then add the working AAAA DNS entry back in.
