Acme.sh: connection reset by peer
eldernode2.ddns.net
acme.sh --issue --standalone -d eldernode2.ddns.net --force --debug 2
GET /.well-known/acme-challenge/PwyV7akv3TROEwM1Ut7-b2V4pxQCy6ea0N0Vhs1y5fQ HTTP/1.1
Host: eldernode2.ddns.net
User-Agent: acme.zerossl.com/v2/DV90
Cache-Control: no-cache
Accept-Encoding: gzip
Connection: close
1< 2023/03/14 15:18:56.278741 length=126 from=0 to=125
HTTP/1.0 200 OK\r
Content-Length: 87\r
\r
PwyV7akv3TROEwM1Ut7-b2V4pxQCy6ea0N0Vhs1y5fQ.QJW1zxMm33dsaIggao6UWppSzRdG2rGiBV73j2_qgjg2023/03/14 15:18:56 socat[1606627] N childdied(): handling signal 17
2023/03/14 15:18:56 socat[1606627] W read(5, 0x55d14231e230, 8192): Connection reset by peer
2023/03/14 15:18:56 socat[1606627] N socket 2 to socket 1 is in error
2023/03/14 15:18:56 socat[1606627] N socket 2 (fd 5) is at EOF
2023/03/14 15:18:56 socat[1606627] N socket 1 (fd 6) is at EOF
2023/03/14 15:18:56 socat[1606627] N exiting with status 0
n/a
ubuntu 20.04
vultr
no
Port 80 and 443 are both CLOSE; Best Practice - Keep Port 80 Open
HTTP-01 Challenge requires Port 80 access; please see https://letsencrypt.org/docs/challenge-types/#http-01-challenge
Using Let's Debug yields these results https://letsdebug.net/eldernode2.ddns.net/1407446; 2 ERRORS
$ curl -Ii http://eldernode2.ddns.net/.well-known/acme-challenge/sometestfile
curl: (7) Failed to connect to eldernode2.ddns.net port 80 after 174 ms: Connection refused
$ nmap -Pn eldernode2.ddns.net
Starting Nmap 7.80 ( https://nmap.org ) at 2023-03-14 15:22 UTC
Nmap scan report for eldernode2.ddns.net (45.76.43.163)
Host is up (0.16s latency).
rDNS record for 45.76.43.163: 45.76.43.163.vultrusercontent.com
Not shown: 990 filtered ports
PORT     STATE  SERVICE
22/tcp   open   ssh
80/tcp   closed http
443/tcp  closed https
1080/tcp closed socks
1443/tcp closed ies-lm
3920/tcp closed exasoftport1
8080/tcp open   http-proxy
8081/tcp open   blackice-icecap
8082/tcp closed blackice-alerts
8083/tcp closed us-srv
Nmap done: 1 IP address (1 host up) scanned in 10.04 seconds
Looks like you're trying to get a certificate from the CA called "ZeroSSL". This is the Let's Encrypt Community. As acme.sh is also an ACME client owned by ZeroSSL, you might have more luck with the ZeroSSL support channels at https://help.zerossl.com/hc/en-us.
This is definitely not the case - opened them in both vultr's firewall and via ufw. Also installed apach2 - it is perfectly accessible from outside.
ah, beg pardon, thought acme is part of letsencrypt :slight_smile:
Kindly wait to see if there are more knowledgeable Let's Encrypt community volunteers willing to assist. :slight_smile:
This is the RFC 8555: Automatic Certificate Management Environment (ACME)
You can use the acme.sh ACME Client to get a cert from the Let's Encrypt ACME Server using --server letsencrypt on the command line
The "peer" presumably being:
If so, then we have no insight as to why that has happened.
Also, be careful with the use/misuse of the:
For me nmap -Pn still say otherwise
Starting Nmap 7.80 ( https://nmap.org ) at 2023-03-14 17:20 UTC
PORT     STATE  SERVICE
22/tcp   open   ssh
80/tcp   closed http
Nmap done: 1 IP address (1 host up) scanned in 9.99 seconds
@ElderOrb, @Bruce5051
What IP is resolved for?:
eldernode2.ddns.net
@ElderOrb, what shows?
curl ifconfig.io
I see this
I saw that too, I'm just making sure both of you are using the same IP.
And that the IP being used is the one where the server is at now.
And https://letsdebug.net/eldernode2.ddns.net/1407650 shows the same IPv4 Address as well.
ANotWorking
ERROR
eldernode2.ddns.net has an A (IPv4) record (45.76.43.163) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
Get "http://eldernode2.ddns.net/.well-known/acme-challenge/letsdebug-test": dial tcp 45.76.43.163:80: connect: connection refused
Trace:
@0ms: Making a request to http://eldernode2.ddns.net/.well-known/acme-challenge/letsdebug-test (using initial IP 45.76.43.163)
@0ms: Dialing 45.76.43.163
@83ms: Experienced error: dial tcp 45.76.43.163:80: connect: connection refused
IssueFromLetsEncrypt
ERROR
A test authorization for eldernode2.ddns.net to the Let's Encrypt staging service has revealed issues that may prevent any certificate for this domain being issued.
45.76.43.163: Fetching http://eldernode2.ddns.net/.well-known/acme-challenge/6zrpz0W1L5VUuZm24qgLFNpHvihIcBm47_pX36SxcIQ: Connection refused
I get two different errors:
curl -Iik http://45.76.43.163
curl -Iik https://45.76.43.163
curl: (7) Failed to connect to 45.76.43.163 port 443: Connection refused
But I'm still not convinced this is the right IP.
curl ifconfig.io -4
45.76.43.163
Please demonstrate.
eldernode2.ddns.net is 45.76.43.163
sure, just installed apache2 :slight_smile:
