About running https web server on not connected to internet devices
I run my web server in an embedded environment, inside a device, needed for configuring device itself. I could have many devices.
My devices can be connected to internet or not, in any case I would like to use https only for connections. It's not clear to me how to manage certificates in this case. Maybe best solution is to always use self-signed certificates? Thanks for any answer.
My web server is (include version): jetty-9.4.25.v20191220;
The operating system my web server runs on is (include version): linux yocto
My hosting provider, if applicable, is: no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): no
I think that's really the only solution, if you need to account for devices that will never be connected to the Internet.
If you control both the client and the server, then yes using self-signed (or a small private CA) is probably the easiest approach. If you need to expose your servers to "general" users where you can't control their trust store, then you can use a public-trusted certificate like Let's Encrypt provides, but you'd need to use a real public hostname for the devices, and probably DNS authentication if the devices can't respond to public requests.
thank-you very much for useful answers!
